Kinetic rotational energy of a bar hooked to a coil
The discussion revolves around the calculation of kinetic energy for a bar connected to a coil, focusing on the application of Koenig's Theorem. The user has derived the kinetic energy formula, incorporating rotational and translational components, but there is confusion regarding the moment of inertia used. It is pointed out that the moment of inertia should be calculated for a rod rotating about one end, not its center. Clarification is sought on whether the term "coil" refers to a spring, and a request for a diagram is made to illustrate the setup. The accuracy of the kinetic energy calculation hinges on the correct application of the moment of inertia for the given configuration.
bznm
I have solved an exercise and I'd like to know if my proceeding about finding kinetic energy is correct or not, because this is the first time that I "meet" a situation like this.
"A bar has mass M and length l. Its extremity A is hooked to a coil (with length at rest l0), its extremity B is hooked to the point O that is the origin of axes."
I have considered three coordinates: x, y (that are the coords of the extremity A on the x-axes and y-axes) and \theta that is the angle that the bar forms with a parallel to the y-axes and I've written
K=\frac{1}{2}I\omega^2+\frac{1}{2}Mv_{cm}^2=\frac{1}{24}Ml^2\dot\theta^2+\frac{1}{2}M(\dot y^2+\dot x^2+\frac{l^2}{2}\dot\theta^2+\dot x\dot\theta l \cos(\theta)+\dot y\dot \theta l \sin(\theta))​
Is it correct? Did I correctly apply Koenig Theorem?
By "coil" you mean "spring"?
Please provide a diagram?
It looks like you are using the moment of inertial for a rad rotating about it's center - but your description has the rod rotating about one end (extremity B).
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Let there be a person in a not yet optimally designed sled at h meters in height. Let this sled free fall but user can steer by tilting their body weight in the sled or by optimal sled shape design point it in some horizontal direction where it is wanted to go - in any horizontal direction but once picked fixed. How to calculate horizontal distance d achievable as function of height h. Thus what is f(h) = d. Put another way, imagine a helicopter rises to a height h, but then shuts off all...
