Thermal & Kinetic Stability: What's the Difference?
The discussion centers on the concepts of thermal and kinetic stability in chemical reactions, using the combustion of methane as a reference point. Thermal stability refers to the stability of products based on their energy levels and the overall enthalpy change of a reaction, while kinetic stability relates to the speed of the reaction and the activation energy required to reach the transition state. A reaction mechanism with lower activation energy will proceed faster, leading to a kinetically stable product, even if it is less stable thermodynamically. When sufficient energy is provided, the reaction can favor the thermodynamically stable product, which is typically more stable in terms of energy but may require a higher activation energy to form. This distinction is crucial in understanding how different reaction pathways can lead to varying product distributions based on stability criteria.
Bladibla
Within the context of the equation:
CH4(g) +2O2(g) -> CO2(g) + H2O(l) delta H = -890 KJ
What is the difference between Thermal and Kinetic stability?
I knew the answer before, but i forgot now. Forgive me for just memorising the answer, but its a temporary solution. Any help would be appreciated!
Chemistry news on Phys.org
Usually when you're comparing thermal and kinetic stability, it's in reference to two different reactions mechanisms with the same reactants. One reaction mechanism might be more kinetically stable, that is since the activation energy of the transition state is lower in energy, the reaction occurs faster, and despite the relatively less "stable" product, it prevails as the product simply because the reaction occurs faster.
If you were to provide enough energy so that the rate of reaction becomes comparably similar, than you would have the thermodynamically stable product as predominant, usually because now the relative proproportion of the products now correlates with the reverse activation energy.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
