Lagrange equations: Two blocks and a string
9 replies · 4K views
Zamarripa
Two blocks, each of mass M, are connected by an extensionless, uniform string of length l. One block is placed on a smooth horizontal surface, and the other block hangs over the side, the string passing over a frictionless pulley. Describe the motion of the system in two cases, first when the mass of the string is negligible, and second when the string has a mass m.
$$T_{string}=\frac{1}{2}m\dot{y} $$
I've problems understanding why the kinetic energy of the string is only
Why the contribution of the string in the horizontal line isn't considered?
PeroK said:
What's the formula for KE?
$$T=\frac{1}{2}mv^2$$
Yes, but what about the contribution on the horizontal?
What contribution from the horizontal?
The problem is that you have ##\frac 1 2 m \dot y## instead of ##\frac 1 2 m \dot y^2##.
The string at the horizontal is also moving
So, what do you think the KE of the string should be?
$$\frac{1}{2}m\frac{(s-x)}{l}\dot{x}$$
where ##m\frac{(s-x)}{l}## is the mass of the string in the horizontal
1) The whole string is moving, so you need the whole mass of the string: ##m##.
2) ##\dot x = \dot y##, as the string is inextensible.
3) You need to use ##v^2 = \dot x^2 = \dot y^2## for KE. You can't use ##\dot x## or ##\dot y##.
