Why Is \(\frac{\partial \dot{q}}{ \partial q} = 0\) in Lagrangian Mechanics?
In Lagrangian mechanics, the expression \(\frac{\partial \dot{q}}{\partial q} = 0\) holds true because \(\dot{q}\) and \(q\) are treated as independent variables in the context of the Euler-Lagrange equation, which is derived from a variational principle. This independence means that variations in \(q\) do not affect \(\dot{q}\), similar to how independent variables function in calculus. When analyzing motion, the Euler-Lagrange equations describe the dynamics in the \(\hat{q_\alpha}\) direction, even when multiple coordinates are coupled. Understanding the relationship between potential energy and the derivatives of the Lagrangian is crucial for grasping the full motion dynamics. The discussion clarifies common confusions regarding the independence of generalized coordinates and their time derivatives in Lagrangian formulations.
AJKing
Question 1
When I take the derivatives of the Lagrangian, specifically of the form:
\frac{\partial L}{ \partial q}
I often find myself saying this:
\frac{\partial \dot{q}}{ \partial q}=0
But why is it true? And is it always true?
[STRIKE]Question 2[/STRIKE] Answer Below
When solving a double pendulum problem I built a Lagrangian of the form:
L(\theta_1, \theta_2, \dot{\theta_1}, \dot{\theta_2})
And found that my Euler Lagrangian equations for each coordinate where coupled to each other, as expected.
But I was a little confused about the direction of motion...
Does
\frac{\partial L}{\partial q_\alpha} = \frac{d}{d t} \frac{\partial L}{\partial \dot{q_\alpha}}
Describe a motion only in the
\hat{q_\alpha}
Direction? Even if the Euler Lagrangian is coupled?
Answer
According to Taylor's text, Classical Mechanics, yes. The \hat{q_\alpha} direction is the only one an Euler Lagrangian equation specifies. But, a true understanding of the motion in that direction comes from:
- \frac{\partial U}{\partial q_\alpha} = \frac{d}{d t} \frac{\partial L}{\partial \dot{q_\alpha}} - \frac{\partial T}{\partial q_\alpha}
Which is used to build:
\vec{F}=-\nabla U
AJKing said:
Question 1
Many a student has been confused by this. The short answer is that the Euler-Lagrange equation is derived from a variational principle using the technique of variations, and ##q## and ##\dot q## are merely labels for the arguments of the Lagrangian.
Consider that you have a function ##F(x, y)##. At some ##(x_0, y_0)## its value is ##z_0##. Now you want to find out its value close to that point. Using the Taylor expansion, you get ##F(x_0 + \delta x, y_0 + \delta y) = z_0 + {\partial F \over \partial x} \delta x + {\partial F \over \partial y} \delta y ##. Now if you had ##x = f(t) ## and ##y = \dot f(t) ##, you would still use the expression above, where ##x## and ##y## are assumed independent. This is exactly what happens when you derive the Euler-Lagrange equation.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
