Can a 4-Potential Approximate Gravitational Field in Weak-Field Limit?
raopeng
I just read some basic concepts on General Relativity, and this idea pops up: I know we should use variations of metrics for gravitational field in the Lagrangian. But considering the resemblance of gravitational field(weak-field) to electromagnetic field, can we construct a 4-potential similar to that of the electromagnetic field, say A_{G} = (ψ(gravitational potential),0, 0, 0). So the Action for the effect of gravitational field would be: \int -\frac{m}{c} A_{G}dx^{i}. Would that be a good approximation for weak field?
No. What you wrote down is identically zero. You should consider the weak field limit directly for the point particle action. So, take this action, write the metric as a
perturbation of e.g. Minkowski spacetime, and perform a Taylor expansion on the square root. Taking static gravity and slowly moving particles should then on its turn give Newtonian gravity, as in e.g. Eqn 2.10 of arxiv:1206.5176.
In the weak field limit GR becomes Fierz-Pauli theory, massless spin 2. A vector potential would mean that gravity is represented by spin-1. In the Newtonian approx. gravity is effectively reduced to a Gallilean scalar field, which could be interpreted as spin 0 (but then with spin defined wrt to the Galilei group).
Eh I was trying to make a parallel comparison to S_{mf}, so the integral is actually \int -\frac{m}{c}ψ d(ct) and when v is relatively small the whole expression does degrade into the classical Lagrangian. But it is a very imprudent thought as I only start to scratch the surface of Relativity Theory. Thank you for your reply that I know where my problem is.
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
