Laminar and turbulent flow, the liquid or object?
A low Reynolds number indicates that viscous forces dominate over inertial forces, resulting in laminar flow. The term "laminar flow" specifically applies to the fluid, not the object itself. The flow around the object can be described as laminar, while the object remains unaffected in terms of exhibiting flow characteristics. Therefore, it is correct to say that the fluid is in a laminar flow regime around the object. This distinction clarifies the relationship between the object and the fluid dynamics involved.
rwooduk
Please could someone verify this statement as I understand things:
If an object has a low reynolds number (or the fluid is very viscous) then it is dominated by viscous forces and inertia plays no role. The object is in a laminar flow regime.
That last part, is it correct? What I'm asking is, is it the object laminar flowing or is it the liquid that is laminar flowing?
Thanks for any help clearing this up.
The term laminar flow applies only to fluids, not objects.
Chet
Likes rwooduk
Chet
Thanks for the reply.
So you would say, the object is subject to a laminar flow regime?
No. If I understand you correctly, rigid objects to not exhibit laminar flow.
Chet
Likes rwooduk
You would say the flow around the object is laminar.
Likes rwooduk
That's great many thanks all.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
