Laplace transform in spherical coordinates
lvotapka
TL;DR
A 1963 paper by Michael Wertheim uses a Laplace transform in spherical coordinates. How is the resulting equation obtained?
Summary: A 1963 paper by Michael Wertheim uses a Laplace transform in spherical coordinates. How is the resulting equation obtained?
In 1963, Michael Wertheim published a paper (relevant page attached here), where he presented the following equation (Eq. 1):
$$ y(\bar{r}) = 1 + n \int_{|\bar{r}'|<R} y(\bar{r}') d\bar{r}' - n \int_{|\bar{r}'|<R, |\bar{r} - \bar{r}'|<R} y(\bar{r}') y(\bar{r} - \bar{r}') d\bar{r}'$$
Where ##\bar{r}## and ##\bar{r}'## are 3-vectors (x, y, z) and ##y(\bar{r})## is a function of one of those vectors. R and n are constants. Note that ##\bar{r}## and ##\bar{r}'## are two different vector variables, the prime does NOT indicate a derivative. He then says he uses a one-sided Laplace transform to obtain the following equation (Eq. 3):
$$t[F(t) + G(t)] = t^{-1}[1 + 24 \eta K ] - 12 \eta [F(-t) - F(t)]G(t)$$
where
$$ F(t) = R^{-2} \int^R_0 ry(r) exp(-sr) dr $$
$$ G(t) = R^{-2} \int^\infty_R ry(r) exp(-sr) dr $$
$$ K = R^{-3} \int^R_0 r^2 y(r) dr $$
$$\eta = \dfrac{1}{6} \pi R^3 n$$
$$t=sR$$
A 3D Laplace transform in spherical coordinates seems rare enough that it is difficult to find resources to reach the latter equations from the first one. I've been able to convert the Laplace transform to spherical coordinates, integrate over the angles, and obtain some equations similar to the latter equations, but not exactly. Clearly, the convolution property of Laplace transforms are used to obtain the RHS of Eq. 3. Any further suggestions or guidance that anyone could provide would be much appreciated.
Thanks for the response. I haven't tried either of those approaches. I'll try to think about how they might help. If you have any suggestions for moving forward using those, I'd be interested to hear them.
I've thought some more about it, and I think I'm pretty close, but still uncertain about the last step...
First of all, I can get the Laplace transform of ##y(\bar{r})## and get something similar to F(t) + G(t) on the LHS of the equation:
\int_0^{\infty} dx \int_0^{\infty} dy \int_0^{\infty} dz y(\bar{r})exp(-\bar{r}\cdot\bar{s})
When converted to spherical coordinates:
\int_0^{\infty} dr \int_0^{\frac{\pi}{2}} d\theta sin(\theta) r^2 y(r)exp(-rs\cdot cos(\theta)) \int_0^{\frac{\pi}{2}} d\phi
Then using u-substitution and integrating over phi and theta:
-\frac{\pi}{2}\int_0^{\infty} dr \frac{r}{s} y(r) + \frac{\pi}{2}\int_0^{\infty} dr \frac{r}{s} exp(-sr) y(r)
The first and second term on the RHS are equivalent to ##y(\bar{r})## equalling 1 and a constant (since the integration is constant with respect to ##y(\bar{r})##).
That just leaves the final term on the RHS:
-n\int_{} d\bar{r} \int_{\substack{|\bar{r}'| < R}{|\bar{r}-\bar{r}'| > R}} y(\bar{r}') y(\bar{r}-\bar{r}') d\bar{r} exp(-\bar{r}\cdot\bar{s})
This is where I seem to be stuck. I'm sure that there is some way to use the convolution property of Laplace transforms to move forward but everything I try seems to be a dead end.
I finally found the answer to my own question. Since it is fairly complicated, I'm not going to give the full resolution here, though if I ever publish the results, I'll try to remember to add a link from this thread to the publication. Alternatively, feel free to message me if you need more specifics.
Indeed, one has to use the convolution property of Laplace transforms in order to get all of the zero boundaries of the Laplace transform to cancel out. Then, one must use a nice math trick for doing a convolution in 3D of a radially symmetric function, which reduces the triple integral to a double integral. After a change in variables, and by assuming that y(r) = y(-r), one obtains the desired result.
