Laplace transform to solve a nonhomogeneous equation
victor77
Mod note: Moved from a Homework section
can i use the Laplace transform to solve a nonhomogeneous equation if
i have these Initial condition s(x) and s(-x)
Hi,
A first order differential equation only needs one initial condition, so the two you have might contradict each other.
A second order needs two. One per differential. So if you have two for the differentiation wrt x only, you are back to the previous problem. And you still don't have anything for ##{d\over dx}({d\over dx})##
Looks like you have a boundary value problem not initial value problem. If your DE is a linear constant coefficient, I think you still can solve it with Laplace transform.
You have to use power series solutions, if the coefficients are non constant. This is just a guess, because you have not posted the DE you have questions on.
Thread 'Direction Fields and Isoclines'
I sketched the isoclines for $$ m=-1,0,1,2 $$. Since both $$ \frac{dy}{dx} $$ and $$ D_{y} \frac{dy}{dx} $$ are continuous on the square region R defined by $$ -4\leq x \leq 4, -4 \leq y \leq 4 $$ the existence and uniqueness theorem guarantees that if we pick a point in the interior that lies on an isocline there will be a unique differentiable function (solution) passing through that point. I understand that a solution exists but I unsure how to actually sketch it. For example, consider a...
