What is the solution to Laplace's equation on a wedge?
tjackson3
Find the solution of Laplace's equation for \phi(r,\theta) in the circular sector 0 < r < 1; 0 < \theta < \alpha with the boundary conditions \phi(r,0) = f(r), \phi(r,\alpha) = 0, \phi(1,\theta) = 0. (also, implicitly, the solution is bounded at r = 0). Use two different spectral representations. (note: this just means do the problem twice, expanding in a different variable each time). Below is a crude MS Paint drawing of the boundary conditions, just to summarize:
http://tjackson3.webs.com/laplace.png
In polar coordinates, Laplace's equation is
\frac{\partial^2 \phi}{\partial r^2} + \frac{1}{r}\frac{\partial \phi}{\partial r} + \frac{1}{r}^2\frac{\partial^2\phi}{\partial \theta^2}
As I said, the goal of this problem is to use an eigenfunction expansion. We have to solve the problem twice - once using the eigenfunction corresponding to r, once using the eigenfunction corresponding to θ. Despite the fact that the θ variable is the inhomogeneous one, I was able to complete the eigenfunction expansion in that one. The problem kicked in for the r variable.
If you do the usual separation of variables (\phi(r,\theta) = u(r)v(\theta), and collect the r terms, you find that the r eigenfunction has to satisfy
r^2 \frac{d^2u}{dr^2} + r\frac{du}{dr} - \lambda u = 0
with the boundary conditions that u(1) = 0, |u(0)| < \infty. Unlike the normal case when you deal with Laplace's equation on a circle, we can't stipulate that \lambda is an integer. There are two cases to consider, and they both seem unlikely. Prior experience leads me to assume \lambda > 0, so for simplicity, let \lambda = \mu^2. Then the solution to the above ODE is
u(r) = c_1 r^{\mu} + c_2 r^{-\mu} = c_1 e^{\mu\ln r} + c_2 e^{-\mu\ln r}
Since u(0) has to be bounded, we know that c_2 = 0. But now the problem is that there's no way to make u(1) = 0 without setting c_1 = 0, which we obviously can't do. Does anyone have any experience with how to get around this problem?
Thanks!
edit: If you assume lambda is negative, then you would get oscillatory functions: u(r) = c_1\sin(\mu\ln r) + c_2\cos(\mu\ln r), which could solve the problem at r = 1, but obviously has trouble as r goes to zero.
I have the feeling that your radial component eigenfunction is the Bessel function of some non-integer order, try to compare Bessel equation to your radial ODE and see if there is a match
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
