Laser Rangefinders: Function and Safety Explained
  • Thread starter cube137
  • Tags
    Laser
In summary: I looking at??In summary, a laser rangefinder works by the laser reflecting off of the object and being measured by the device. If the object is not reflective, the laser rangefinder will not work. Reflectors (like cube corner retro-reflectors) are used to measure distances with a laser rangefinder.
cube137
361
1. Laser rangefinder is said to work by the laser reflecting from the object and the device measuring the distance.. but if the object is not reflective.. how can the laser bounce back?
2. Is the laser in the Laser rangefinder harmful to the eyes?
Science news on Phys.org
If the object absorbs too much of the laser light, then no, you will not be able to use a laser rangefinder for the job.
As to eye safety, that is covered in the wikipedia article: https://en.wikipedia.org/wiki/Laser_rangefinder
:smile:
:smile:
how about concrete surface like in buildings.. how can it even reflect off concrete??
Use a window instead, or some other surface like metal that reflects well.
Also, did you read the wikipedia article? What do they suggest when the object is not very reflective? :smile:
I read it two times. It didn't suggest what to do if objective is not very reflective.. just black laser absorbing paint for military use.
Anyway. It's not written there what if the target surface is in an angle.. then the laser would bounce off an angle too.. but for the laser to bounce back to the device.. the surface has to be exactly 90 degrees to the line of site.. how often can you find such surface in the field??
It said to use reflectors (like cube corner retro-reflectors). That's what surveyors use in their work with laser rangefinders. :smile:
I'll use it to measure the distances of buildings.. if the laser hits the concrete from an angle.. how can it reflect back to the device? Do you think it will work? Thanks :)
Laser light reflects off of concrete. If light didn't reflect off concrete, it would be black, not white!
Makes sense. But if you hit it off at say 30 degrees from the sides, how can it return to the device, it should go on the other side.
I want to use it to estimate the distances of buildings because I'm studying the effect of binocular magnification and depth of field. How come lower magnification has larger depth of fields. For example. 7X binocular has objects in focus more than 25 yards? While 8X has shallow depth of field. What physics principles makes this happen? I want to use laser rangefinder to get the distances to the target.
Most surfaces are not mirror like in their reflection property. For most surfaces the light is scattered in all directions and some gets back to the receiver.
What happens if the building is made of glass?
Look, you need to go put cube corners on these buildings temporarily for your surveying of the distances for your project. Just have two people do the surveying. That is so standard... What is so hard to understand about this?
https://www.amazon.com/dp/B00EF30VWA/?tag=pfamazon01-20
see above product.. it's supposed to be shoot and read... why.. does it only read for few selected targets only?
I didn't find that on a quick skim of the link but why do you think it says that?
Are you looking to use a laser rangefinder for an application? What is your application?
I have a binocular. I want to see the distance to any target...
There are other ways to do this.
There are inexpensive rangefinders that use parallax to estimate the distance. Have you looked at those? Why do you need to estimate those distances?
I understand to study the relationships between magnification of binocular and depth of fields.. lower magnification has greater depth of fields (meaning more objects in focus). I heard when you use 7X binocular.. everything beyond 25 yards is in focus.. but for higher magnification.. they are not in focus.. know the formula for determining magnification and depth of field? Thanks.
So for that you should be able to use a simple visual estimation of distance, IMO.
that doesn't even begin to make sense
read this wiki link on DOF
https://en.wikipedia.org/wiki/Depth_of_field
Dave
Which, again, is why you can see them!
I looked into this, a while ago, when I was with the National Coastwatch Institute (UK). There don't seem to be any parallax-based rangefinders available, except for some ancient WW2 models and that seem to be more like collectors' items.
I bought a cheap IR laser device that has a range, very dependent on the reflectivity of the target (max only a couple of hundred m). If you can't see a distant target then neither will the rangefinder.
If you can see the object it is reflective.
But the converse is not necessarily true. "Stealth" construction, with highly reflective mirrors can give good specular reflections but in the wrong direction and you may see light, reflected from an object but due to light from other directions but the laser beam will not be reflected back to the rangefinder.
Likes Buckleymanor
1. What is the function of a laser rangefinder?
A laser rangefinder is a device that uses laser beams to determine the distance between the user and a target object. It works by emitting a laser pulse towards the target and measuring the time it takes for the pulse to bounce back to the device. This information is then used to calculate the distance to the target.
2. How accurate are laser rangefinders?
The accuracy of a laser rangefinder depends on various factors, such as the quality of the device and the conditions in which it is being used. Generally, most laser rangefinders have an accuracy of within 1 yard or meter.
3. Are there any safety concerns when using a laser rangefinder?
Yes, there are safety concerns when using a laser rangefinder. The laser beam emitted by the device can be harmful to the eyes if directly pointed at them. It is important to always follow the safety instructions provided by the manufacturer and to never look directly into the laser beam.
4. Can laser rangefinders be used in all weather conditions?
Most laser rangefinders are designed to be used in a wide range of weather conditions, including rain, fog, and snow. However, extreme weather conditions such as heavy rain or snowfall may affect the accuracy of the device. It is always best to consult the manufacturer's guidelines for specific weather limitations.
5. How do I maintain and care for my laser rangefinder?
To ensure the accuracy and longevity of your laser rangefinder, it is important to regularly clean the lens and keep it protected when not in use. It is also recommended to store the device in a dry and cool place. If any issues arise, it is best to contact the manufacturer for maintenance or repairs.
  • Optics
  • Biology and Medical
  • Optics
  • Atomic and Condensed Matter
