Answer: Calculating Lattice Binding Energy of MgO Crystal
devillenator
In a crystal lattice of MgO, the Mg is surrounded by 6 Oxygen atoms as shown.
Assume that the ions all behave as point charges.
If the system behaves as though there were separate interactions between Mg and each of
the Oxygen ions what is the total binding energy of the Mg ion?
F_c = -K/a^2
F=\frac{dE}{da}
F=F_c+F_R
so I'm quite confused with this question.
I can find the coulombic force of attraction using F_c = -K/a^2 if i take a to be the equilibrium bond length and look up values for the ionic radii.
Now that i know the attraction force i can then work out the repulsive force as at the equilibrium bond length the attractive force is balanced by the repulsive force.
my problem is that because the forces balance the net force is zero , so what is the total binding energy of the iron.
would anyone agree that the question is asking for the electron binding energy and that i was trying to find the wrong thing?
im still stuck with this.
Thanks
Sean
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
