Launch Velocity of Spacecraft at ISS: Solving for v_L
  • Context: Graduate
  • Thread starter Thread starter compwiz3000
    Iss Spacecraft
The discussion revolves around calculating the launch velocity required for a spacecraft to reach a circular orbit around the Earth at a height of 357.1 km, specifically in relation to the International Space Station (ISS). Participants explore concepts of energy conservation, orbital mechanics, and trajectory planning.
  • Experimental/applied
  • One participant proposes using energy conservation principles to equate mechanical energies to find the launch velocity, suggesting the equation - \frac {\mu}{2\left(r_E + h\right)} = \frac {v_L^2}{2} - \frac {\mu}{r_E} as a basis for their reasoning.
  • Another participant notes that achieving the necessary launch velocity would result in a satellite with a perigee above the Earth's surface, emphasizing the importance of the Earth's rotation in determining the effective launch velocity.
  • A participant questions the meaning of "needed velocity at launch" and seeks clarification on the initial approach to calculating launch velocity.
  • One participant describes the trajectory needed to reach the ISS, mentioning the initial vertical velocity and the subsequent need for a velocity boost to maintain a circular orbit, citing specific speeds and altitudes.
  • Another participant identifies the described trajectory as a Hohmann transfer orbit and inquires about the potential velocity savings associated with this method.
  • There is a discussion about the feasibility of directly launching to the ISS, with one participant suggesting that safety considerations necessitate reaching a sufficient orbital velocity quickly.
  • Concerns are raised about the implications of using energy conservation laws with initial thrusting and the resulting orbital characteristics, indicating that such an approach may not yield sufficient velocity for circular motion.
Participants express differing views on the launch trajectory and the implications of energy conservation in determining orbital mechanics. There is no consensus on the best approach to calculating the launch velocity or the feasibility of direct launches to the ISS.
Participants discuss various assumptions regarding orbital mechanics, including the effects of Earth's rotation, atmospheric drag, and the nature of elliptical versus circular orbits. Specific numerical values and conditions are mentioned but not universally agreed upon.
This discussion may be of interest to those studying orbital mechanics, spacecraft trajectory planning, and energy conservation in physics, particularly in the context of space missions and satellite launches.
compwiz3000
If we launch a satellite to a circular orbit around the Earth at height 357.1 km, to find the velocity needed at launch, do we just set the energies equal?:
[tex] - \frac {\mu}{2\left(r_E + h\right)} = \frac {v_L^2}{2} - \frac {\mu}{r_E}[/tex]
and then solve for [tex]v_L[/tex]?
[tex]\mu = GM[/tex], where [tex]M[/tex] is the mass of the Earth.
Then, in space, the mechanical energy is
[tex] \frac {v^2}{2} - \frac {\mu}{r}.[/tex]
Using centripetal force, we have
[tex] \frac {m v^2}{r} = \frac {\mu m}{r^2} \implies v^2 = \frac {\mu}{r},[/tex]
so the mechanical energy is
[tex] - \frac {\mu}{2r}.[/tex]
Since the mechanical energy is conserved at the surface, we set it equal to that mechanical energy to find the launch velocity.
and then solve for [tex]v_L[/tex].
Is my reasoning for the launch velocity correct?
If you gave the satellite the needed velocity at launch, the satellite would orbit the Earth with a perigee that would be several miles above the treetops. Secondly, because the Earth is rotating with an angular speed of over 1000 mph at the equator, the easterly velocity at Cape Canaveral is about 1000 cos(28 degrees) = 880 mph.
What do you mean by "needed velocity at launch"?
And is my approach correct?
You have correctly identified the vertical velocity required to reach the ISS orbit, and the ISS orbital velocity, but the actual trajectory is probably one that first reaches the top of the atmosphere (50 Km?) and an orbital velocity (~7880 kps (kilometers per sec))that would be needed to reach the minimum orbital momentum and maintain a circular orbit in case of loss of thrust. Then, by boosting the velocity to about 7960 kps, the satellite would be on an elliptical orbit that would reach the ISS orbit as an apogee. But when arriving at the ISS orbit, its velocity would be only 7610 kps, so it would have to boost its velocity to about 7700 kps to maintain a circular orbit. At this time, its period would be about 91.6 minutes. By dropping down 10 km in altitude, it could shave maybe 12 sec per revolution and catch the ISS in a few turns if necessary.
The path you are describing is the Hohmann transfer orbit, right?
How much velocity boost would I be saving in your case?
It is not feasible to directly launch to the ISS?
Also, if I use the energy conservation law with an initial thrusting of [tex]v_i[/tex] and a final velocity of [tex]0[/tex], the satellite would not have enough velocity to undergo circular motion, correct?
compwiz3000 said:
The path you are describing is the Hohmann transfer orbit, right??
Yes.
How much velocity boost would I be saving in your case??
Don't know.
It is not feasible to directly launch to the ISS??
For safety reasons, the satellite has to quickly reach an orbital (not vertical) velocity that will have sufficient angular momentum to circle the Earth above the atmosphere.
Probably not. Any orbit that begins on the Earth with final velocities will be on an elliptical orbit (neglecting air drag) that intersects the Earth in less than one revolution.
  • · Replies 21 ·
  • · Replies 63 ·
  • · Replies 30 ·
  • · Replies 17 ·
13K
