Can the Law of Universal Gravitation Override Earth's Gravity?
The discussion centers on the application of Newton's Law of Universal Gravitation to two rings of differing masses (3 kg and 2 kg) placed extremely close together (1.0 x 10^-9 m). The calculated gravitational force between the rings was 400.2 N, while the weight of the smaller ring was 19.6 N. However, it is established that the gravitational force exerted by Earth is significantly stronger, and the configuration of the rings would not result in the smaller ring floating within the larger one, as it would experience no net force from the larger ring.
  • Understanding of Newton's Law of Universal Gravitation
  • Basic knowledge of gravitational force calculations
  • Familiarity with mass and weight concepts
  • Concept of center of mass in physics
  • Study the implications of gravitational force in multi-body systems
  • Learn about the concept of net force and equilibrium in physics
  • Explore advanced gravitational theories beyond Newtonian physics
  • Investigate practical applications of gravitational interactions in engineering
Students in physics, educators teaching gravitational concepts, and anyone interested in the fundamental principles of gravitational interactions.
c.evans
We just started on a chapter about gravity in my physics class. I'm curious about this: If two rings of different radius and masses of, say, 3 kg and 2 kg, are placed inside each other so that their centers of mass are extremely close (i.e. 1.0 x 10^-9 m) together, would the gravitational force between the two objects be enough to overcome the gravitational force of earth, so that the smaller ring would float in midair within the larger ring? When I put these values into the equation for Newton's Law of Universal Gravitation, the force between the two rings came out as 400.2 N, while the force of the weight of the smaller ring came out as 19.6 N. Is this possible, or am I using the equation the wrong way?
Nope. First, the gravity on Earth is much stronger than anything your rings would have. I don't know the exact amount, but your number seems absurdly hi for some reason.
Also, the rings would never float in your example anyways. Placing a ring inside another ring wouldn't do anything. The inside ring would feel no net force in any direction to the larger ring.
  • · Replies 29 ·
  • · Replies 41 ·
  • · Replies 16 ·
  • · Replies 16 ·
