What is the Relationship Between Leak Rates and Different Gases?
  • Thread starter Thread starter madanitsuj
    Gases
The discussion centers on determining the equivalent leak rate of a tank when switching from hydrogen to gases like nitrogen or oxygen, given known pressure, temperature, and flow rate. It emphasizes that the leak rate is influenced by the viscosity of the gases involved, with a decrease in leak rate proportional to an increase in viscosity. Understanding compressible flow is essential, and the ideal gas law is referenced to relate the properties of different gases. The conversation highlights the importance of gas constants specific to each gas type in calculating leak rates. Accurate assessments of leak rates require consideration of these factors.
madanitsuj
Hi Everyone,
I have a problem that I've been working on and I'm having a little trouble. Essentially I have a tank with a known leak rate at a given pressure and temperature. We are currently using hydrogen, but I need to know what the equivalent leak rate would be if we changed the gas to say nitrogen or oxygen. Assuming I have the known values of pressure, temperature, and flow rate, would it be possible to determine the leak rate that we would be detect if we input a different gas and pressurized to the same pressure as before?
Thanks in advance
Hi
if you know that leak occurs at tank sealing, it should be sufficient to compare the viscosity of the hydrogen and of the gas you are supposed to utilize. The leak (dot_q) decrease proportionally to the viscosity (eta) as dot_q propto 1/eta.
M
Basically, for a gas, you need to understand compressible flow
Fundamental equation
PV=nRT or see http://en.wikipedia.org/wiki/Ideal_gas_law
n is basically your gas constant that is different for the type of gas you have.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
