Learn the Derivation of Motion Equations with Expert Guidance
  • Thread starter Thread starter Omar
    Derivation
The motion equations s=ut+0.5at^2 and v^2=u^2+2as are derived from the definition of acceleration as the second derivative of position with respect to time. When acceleration is constant, integrating the acceleration equation leads to the velocity equation, v=at+v_0, where v_0 is the initial velocity. Further integration of the velocity equation provides the position function, x(t)=0.5at^2+v_0t. The second equation can be derived through algebraic manipulation and substitution of the acceleration definition into the position equation. Understanding these derivations is essential for grasping the fundamentals of motion in physics.
Omar
Hello,
I'm new to the forums. This is my first thread here. I just wanted help in knowing where the motion equations (s=ut+0.5at^2, and v^2=u^2+2as) are derived from?
Thanks in advance..
They are a consequence of the definition of acceleration as the second derivative of position (as a function of time). When the acceleration is constant, it's easy to find the velocity by doing a very simple integration.
x''(t)=a
x'(t)=at+v_0
The constant term is the velocity at time t=0. If we integrate this, we find the position as a function of time.
x(t)=\frac{1}{2}at^2+v_0t
I could have added a new constant term that would have represented the position at time t=0, but this is usually chosen to be zero.
The second equation in your post can be derived from the velocity and position equations above.
fundamentally they were derived from equation of acceleration.
start off with the definition of acceleration...
a = \frac{v_f-v_0}{t}
v_f = v_0 + at
Definition of average velocity...
v_{ave} = d/t
d = \frac{v_f + v_0}{2}t
substitute...
d = \frac{(v_0+at) + v_0}{2}t
d = \frac{2v_0 + at}{2}t
d = v_0t + \frac{1}{2}at^2
For the second equation...it just a lot of manipulation of the equation above and a substitution of the definition of accleration.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
