Length contraction of particles
member 529879
As an object moves, it is contracted in the direction of it's motion. Why wouldn't each individual subatomic particle be contracted rather than the object as a whole?
Our current best theories indicate that subatomic particles are having no size at all, thus there would be nothing to contract. Contraction/dilation of space/time is an observer effect.
The force fields of subatomic particles are contracted:
http://en.wikipedia.org/wiki/Length_contraction#Experimental_verifications
  • Heavy ions that are spherical when at rest should assume the form of "pancakes" or flat disks when traveling nearly at the speed of light. And in fact, the results obtained from particle collisions can only be explained when the increased nucleon density due to length contraction is considered.[11][12][13]
  • The ionization ability of electrically charged particles with large relative velocities is higher than expected. In pre-relativistic physics the ability should decrease at high velocities, because the time in which ionizing particles in motion can interact with the electrons of other atoms or molecules is diminished. Though in relativity, the higher-than-expected ionization ability can be explained by length contraction of the Coulomb field in frames in which the ionizing particles are moving, which increases their electrical field strength normal to the line of motion
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
