Length Contraction: Solving for L
The discussion revolves around solving for the length of a moving rod using the concept of length contraction in special relativity. The proper length L_0 is defined in the S' frame, while the observer in the S frame measures the contracted length L. Key equations include L = L_o / gamma and the relationship involving the angle θ_0, where the horizontal component of the length contracts. Participants clarify that the contraction only affects the component of the rod's length parallel to the direction of motion, leading to the conclusion that L = L_o [1 - (v^2 / c^2) cos^2 (θ_o)]^(1/2). The discussion emphasizes the importance of understanding the geometry of the situation to accurately apply these concepts.
Herricane
A rod of length L_0 moves with a speed v along the horizontal direction. The rod makes an angle of θ_0 with respect to the x'-axis.
a. Show that the length of the rod as measured by a stationary observer is given by L = L_o [1 - (v^2 / c^2) cos^2 (θ_o) ]^(.5)
L = L_p/ gamma
I have a few questions:
Is L proper L_o (the S frame?)
When I am trying to find the length of the rod as measured by a stationary observer do I refer to the graph to the right?
Horizontal length is all I need to worry about, correct?
L = L_o / gamma
x' = L cos θ_o
x' = x ( 1 - v^2/c^2 )^(-1/2)
L cos θ_o = x ( 1 - v^2/c^2 )^(-1/2)
L = x / [ (1 - v^2/c^2 )^(1/2) cos θ_o ] where x = L_o
L = L_o / [ (1 - v^2/c^2 )^(1/2) cos θ_o ]
Am I on the right track? I can't seem to make it look like:
Wait, huh, is the picture you attached one given by the problem or something you made? The picture is really different from how I read the problem.
The way you're approaching the problem seems fine. But if you're going to find the x coordinates, you need to find two x coordinates because length is x2-x1. Looks like you're doing a strange mixing of length contraction and x coordinates. Either approach is okay, but you'll probably confuse yourself going between them (confused me at least).
Yes I think that is my problem. I don't know how to draw the diagram. Can you explain me what you understood? I have read it several times and I just don't get it
So you have an S' that moving relative to the S frame; their x-axis is collinear. In S' we have a proper length L_o, and the length makes an angle with respect to the x' axis. So the part that will be contracted is L_o*cosØ'. L_o*sinØ' will stay the same in both frames. S even sees a different angle than S' does.
Thank you, I figured out the problem. I was making it way too complicated.
