Calculating Ellipse Length: 9x^2 + 10y^2 = 90 (to 6 decimal places)
  • Thread starter Thread starter wilcofan3
    Ellipse Length
wilcofan3
Find the length of the ellipse 9x^2 + 10y^2 = 90 correct to six decimal places.
4Larc in the first quadrant = Lellipse
Just checking to see if I did this right:
9x^2 + 10y^2 = 90
x^2/10 + y^2/9 = 1
Therefore a = \sqrt{10} and b = 3.
This makes x = \sqrt{10}sin t and y = 3 cos t
Since \int \sqrt{(dx)^2 + (dy)^2} is the formula for arc length, do I just get: 4\int \sqrt{10(cos t)^2 - 9(sin t)^2}?
And are the bounds just from 0 to \pi/2?
Thanks!
9x^2 + 10y^2 = 90
x^2/10 + y^2/9 = 1
This is the formula: \int \sqrt{(dx/dt)^2 + (dy/dt)^2}dt
There's a mistake in the line above. What do you get when you square dy/dt? Also, don't forget your dt in the integrand.
Thanks!
Yes.
You should be aware that the calculation of the circumference of an ellipse results in what is known as an "elliptic integral" which cannot be done in terms of elementary functions.
The instructions provided by the OP imply that numerical integration is to be performed.
Oh, is it just that it should be positive instead of negative? That's the only thing I'm seeing, and yeah, I need to put the dt in there.
So, other than that, is it correct?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
