Lenz's law - magnetic fields and Currents
Lenz's law explains that the induced current in a loop is determined by the change in magnetic flux through it. In the scenarios presented, the current in situation B is equal to that in situation A because the direction and magnitude of the change in flux are the same for both situations. The top half of loop B experiences an increasing magnetic field, while the bottom half experiences a decreasing field, resulting in a net change that matches situation A. This understanding clarifies why the currents are equal despite the differing conditions. The key takeaway is that the change in flux, not the absolute values of the magnetic fields, dictates the induced current.
kidi3
Hey Pf..
I am trying to understand Lenz's law, but somehow it doesn't make sense.
In my book there is some checkpoints execise to test wheather you've understood what you read about, one those checkpoints looks like this.
http://snag.gy/NCNLh.jpg
I do understand why the current in situation a is the highest since the magnetic field is increasing will it never become zero, and in situation C will the current decrease until become constant (B=0)=> current =0.
But why should the current in situation B be as high as in situation A.. ?
Take note of the direction of the magnetic field in each half of the loop.
It's both in and out.. but wouldn't the dec. part go to 0, and lead the B to become ½A..
I can see B would be as high as A in a short moment,should it not be ½A thereby lead B<A
No.
What matters is the change in the flux through each half of the loop.
In the top half (of B) which way does the field point? Since it's increasing, which way is the change in flux pointing?
Same question for the bottom half. Which way does the field point? Since it's decreasing, which way is the change in flux pointing?
Ah.. they all point in the same direction, and since change is equal to the one in situation A, they must be equal in magnitude..
Exactly. The change in flux through each half of B points in the same direction, just like it does in A.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
