Let Y denote the following subset of ( )
  • Thread starter Thread starter Jamin2112
Jamin2112
Let Y denote the following subset of ... (URGENT!)
None.
Halp! This is the last problem on my homework which is due tomorrow.
I don't know how to start this because, according to my textbook (Munkres), when we check whether a set A is open in Y, we are asking whether it belongs to the topology of Y. But I know nothing about the topology of Y, the subspace topology, because I first need to have a topology defined on ℝ2 in order to have a subspace topology.
From the book:
Definition. Let X be a topological space with topology T. It Y is a subset of X, the collection
TY = { Y intsct U | U in T}
is a topology on Y, called the subspace topology.
i haven't studied topology, but I've studied a little bit of metric spaces. do you use concepts like open balls to show a set is open?
Yes.
okay, so for the first one, can you construct an open ball around any point in A that is contained in A? If you look at Y on a cartesian plane, you have all the points (x,y) where x>0, and y>=0. if you look at A, you have all the points where x>0, and y>0. for every point a=(xo,y0) in A, is there some r>0 st S(r)(a) is contained in A? (Sorry if my notation is a bit off). It looks like it. if you take r to be the min of d(x,0) and d(y,0), then shouldn't that ball be contained in A?
alternatively, what about it's complement? if it's complement is closed, then your set is open, right?
btw, there are relevant equations. what is the definition of open and closed?
Yes.
And when I look at the complement of A to see whether A is closed, I'm looking at Y\A is see if for every x in Y\A there exists an open ball containing x and contained in A. Right?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
