Light intensity and index of refraction
The discussion centers on whether the amplitude of Poynting's vector changes when electromagnetic waves transition between different media. Participants argue about the conservation of energy, photon density, and the relationship between wave velocity and intensity. It is noted that while the speed of photons decreases in a medium with a higher index of refraction, the total power per area remains constant due to the assumption of no absorption. The conversation highlights that although photon density increases, the flow of photons per second remains unchanged. Ultimately, the consensus suggests that while the intensity may appear constant, the behavior of Poynting's vector in different media is complex and influenced by reflection and transmission.
Nikitin
Hi. Will the amplitude of Poynting's vector change if the electromagnetic wave goes from one medium to another?
Shouldn't the amplitude remain constant due to conservation of energy? I.e. the photon-density and velocity will change, but their total intensity remains the same.
I could always do the calculations from maxwell's equations, but it seems like too much bother right now if one of you guys already know this (I'm tired).
Thanks
Science news on Phys.org
Why? If the wave propagation gets slower, the energy density goes up (because the flow stays constant if we can neglect losses).
But if the wave propagation gets slower, less photons are going thru the surface in question.
Btw, I am talking about linear mediums only!
No. Why do you think that?
Yes I expected that.
If the velocity of the photons is less, then fewer photons, per second, are passing thru the surface. So you could say that the photon flow gets "denser" if the light enters a medium with higher index of refraction than whence it came.
Sorry, I neglected to add the per second bit
No. All photons that go in will go out (this is exactly the "no absorption" assumption). If their speed gets lower, their density increases, but flow (here: photons per second) stays constant.
Yes this is basically what I was saying with "doesn't the amplitude of Poynting's vector stay constant?".
So the intensity remains unchanged, right?
Didn't you imply that the intensity does not remain constant for the light beam, in the beginning?
Power per area stays constant. I don't know how the Poynting vector is defined in a medium.
There is always reflection. Reflected intensity + transmitted intensity = incoming intensity.
Surely if the power per area stays constant, poynting's vector must stay constant?
  • · Replies 41 ·
  • · Replies 17 ·
