Determining Mica Thickness Using Interference Fringes
The discussion focuses on calculating the thickness of mica used in a double slit interference setup, where the mica covers one slit and shifts the central maximum to the 9th bright fringe. The relevant equation for determining thickness is derived from the path difference caused by the mica, expressed as (xb/L) = (n-1)t, where t represents the mica thickness. Users seek clarification on how to apply the equation, specifically what values to use for L (distance to the screen) and x (fringe distance). The wavelength of light used is 556 nm, and the refractive index of mica is 1.58. The conversation emphasizes understanding the relationship between interference patterns and the physical properties of the materials involved.
inflames829
A thin flake of mica (n= 1.58) is used to cover one slit of a double slit interference arrangement. The central point on the viewing screen is now covered by what had been the 9th bright fringe before the mica was used. What is the thickness of mica if light of wavelength 556nm is used? answer in microns
n lambda = xb/L
where
λ is the wavelength of the light,
b is the separation of the slits, the distance between A and B in the diagram to the right
n is the order of maximum observed (central maximum is n=1),
x is the distance between the bands of light and the central maximum (also called fringe distance), and
L is the distance from the slits to the screen centerpoint.
This is the only equation i can find so i assume you use it. Is this correct? and if so can someone give me hints on what values to put in for L and x. please. THANKYOU
The path difference when one slit is covered with mica will be slightly different.
\frac{xb}{L} = (n-1)t
where t is the thickness of the mica.
