matheinste said:
Quote:-
-Like I said, there are two concepts here, the static concept distance and the dynamic concept "distance traveled". The latter is what we measure, not the former. . -----
I still don't see the relevance of anything that you say. All this, whatever it might be, is an unecessary sidetrack to the very simple explanation of the observers of the moving mirror. Can't we leave out any complications. The original question has been given the standard reply, that found in any textbook that uses this example. If the questioners had to rely only upon your response i think they would have been confused and misled.
Matheinste
The relevance is this. How is the distance between two objects anything like the distance-traveled by one object?
Distance:
B
Distance-traveled:
--------0
B--------
Dashed lines are the floor and ceiling of the train. The 0 is the flashlight and the B is the spot on the ceiling.
Distance is a static concept, in the illustration of this concept we are looking at single cross section of time. We are looking at a SINGLE location of objects. We are looking at the locations of the flashlight and the ceiling respectively.
Distance-traveled is a dynamic concept, in this illustration we are looking at 2 instants. We are looking at SUCCESSIVE locationS of objects. This requires one to remember where an object was and also to see where it is now. We are looking at the location of the flashlight, recording it, THEN looking at the location of the ceiling *after the photon arrives*.
Consider the second illustration, you're standing on the dashed line (floor of train). You see the first picture and then the second. This corresponds to the guy on the train first seeing the flashlight turn on, then seeing the ceiling spot. Now consider the guy standing on the ground outside the train. This situation looks like (S is just a spacer):
--------0
GGGGGG
S--------
SB
S--------
GGGGGG
The person standing on the ground remembers where the object WAS and sees where it is NOW. Never did the distance between the flashlight and the ceiling change because distance has nothing to do with motion. Distance cannot change because "change" invokes motion i.e. is dynamic. We need only one picture/illustration to show distance, we need at least two pictures to illustrate distance-traveled.
Both the person on the train on the ground are correct in their measurements of
distance traveled. Any conclusions they draw about the
distance between the flashlight and the ceiling based on this measurement is equivocating two explicitly different concepts. Distance is not relative and does not depend on perspective or observers. The static separation between two objects doesn't care if you're drunk, blind, or flying an F-15.
Finally, after laying out the basic conceptual issue, the guy on the train and the ground are idiots to be surprised at getting different results. Everyone learns somewhere in their elementary education that all measurements require a reference standard. The two people are measuring distance-traveled using different references. The guy on the train is measuring the distance-traveled by the photon relative to the train and the guy on the ground is measuring distance-traveled relative to the ground. Only someone with no education or logical reasoning would be surprised by different results. Indeed the guy on the ground can get the same result as the guy on the train simply by measuring the distance-traveled by the photon relative to the train. This is elementary level stuff. I say the height of the cup is 12 and you say it's 30.48. We're using different
reference standards, that's all! Would you be shocked that I got a different result when I measured in inches vs. centimeters? Shall we conclude that the cup contracts for me? Or that the space within it contracts for me?
ZikZak said:
altonhare:
I am skateboarding down the street with a tennis ball in my hand. Over the course of one second, I observe the tennis ball and measure it to be at rest, to have covered no distance at all. My friend, standing on the sidewalk disagrees and claims that the tennis ball traveled quite far. Whose observation is "real," and whose is the "illusion," and how do we tell?
Perhaps "illusion" was a poor word. What is going on here is a misintegration of concepts, a basic and fundamental conceptual error. First of all whether something is "at rest" or not is not a matter of measurements, observations, or
anyone's personal opinion. Whether an object moved or not is a matter of definitions. The definition of motion is "two or more locations of an object". Where "location" is the set of distances from an object to every other object in the universe. So, if the ball is at more than one location, then it moved by definition, whether you personally saw it move or not.
The other problem is that you two are not using a common reference standard, which is a very basic and necessary thing for any measurement. You are measuring the ball's distance-traveled relative to your chest (for instance) and the guy on the sidewalk is measuring the distance-traveled relative to the sidewalk. If you two use the same reference standard, you will both get the same result. Just like if we use the same ruler we will get the same result and if you use a metric ruler and I use British we will get different results, but can reconcile our different quantities by comparing reference standards. You on your skateboard can reconcile the different result (0 distance traveled of the ball) with your friend's (X distance-traveled by the ball) by comparing your reference standards. Your friend says his reference standard is the sidewalk, on which there are even marks (as on a ruler). You say yours is your arm, on which there are even marks (as on a ruler). Now when you go back to where you started boarding and look at your *friend's* reference standard you will conclude the same as him.
Which one is "right"? All knowledge is contextual and ALL measurements involve a reference standard.
Michel:
I intentionally left out what Einstein calls the "relativity of simultaneity" because it only complicates matters. Just because I detect a photon before you has nothing to do with if an event was simultaneous or not. Differing conclusions about simultaneity are, again, due to differing reference standards and nothing deeper.
We can illustrate this. Two balls strike a table at eye level simultaneously and emit a photon as they strike it while I run toward them and you run away from them (S is a spacer b/c of the forum's parser and P is a photon): Osssssssssssssssssssssssssssss
PBBPssssssssssssssssssssssssssssssO
\|/ssssssssTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTsssssssssss\|/
|ssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssss|
/ \sssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssss/ \
ssssssOssss
BBsssssssssssssssssss
Pssssssssssssssss O
sssss\|/ssssTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTssssssssssssssss\|/
ssssss|sssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssss |
sssss/ \sssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssss/ \
ssssssssO
BBsssssssssssssssssssss
PssssssssssssssssO
sssssss\|/ssTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTsssssssssssssssss\|/
ssssssss|sssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssss|
sssssss/ \ssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssss/ \
Left guy says,"The balls hit now!"
The guy on the right hasn't seen them yet because he's moving away from the photon. Later on he'll say,"They collided now!"
Does either of their opinions change the *physical situation*? What if one is drunk or has a mental disorder? Will that change what happened? Because a photon's speed is finite, and so people absorb them before or after other people, does the situation change *physically*? In fact, if the two are aware that light is not instantaneous, they should not be at all surprised by their differing results! This is elementary, one surprised by this result is assuming light is instantaneous or doesn't understand the concept of a measurement.
The Lorentz transforms are just a way to reconcile different reference standards. Conceptually it is no different than using a unit conversion such as 2.54 cm = 1 inch.
