Light Wave Amplitude: Variation & Length Explained
In summary: Thanks for the clarification. So the amplitude of a wave is constant, but it can still change due to dispersion? Yes, dispersion can cause the amplitude to change. But the amplitude is always related to the electric field, which is always constant in vacuum.
DB
501
Maybe this should be under QM but it's a pretty simple question. How does the amplitude of a light wave varie (if it varies at all), if it doesn't what is the lenght?
Science news on Phys.org
QM doesn't account for amplitudes of light waves.Classical electrodynamics does.
Depends on the situation.In the most common & simple cases of propagation through vacuum,it does't vary at all.But,as soon as the wave interacts,sure,the amplitude and the wavelength can vary.
Daniel.
The amplitude^2 of lightwaves is equivalent to the number of photons. It doesn't change spontaneously, it changes when it interacts with matter, where each photon either transmits, reflects, scatters, or gets absorbed.
Thanks.
So,
[tex]amplitude=\sqrt{number \\\ of \\\\ \gamma}[/tex]
But isn't the # of photons a probability? How do you go about getting the # of photons?
No not equal, but "proportionnal to". By equivalent, I mean it's two ways of talking about the same thing. In the case of a monochromatic plane wave, if you know how many [tex]Js^-^1m^-^2[/tex] (beam intensity or power), well this number should be the same as [tex]Nhfs^-^1m^-^2[/tex], N being the number of photons.
Any good EM text should show how to relate beam amplitude to power (Poynting vector etc.).
So the strong the beam intensity the higher the amplitude? Why is this?
Because beam intensity is power (J/s/area), and beam amplitude is an electric field (or the often neglected magnetic field).
Your question now comes to : "the higher the electric field, the more energy there is?". Well, it certainly makes sense. I'll come back later...
this confuses me a lot too...
When we say light is a wave, it's not some undefined wave of something we don't know about. Light is specifically an oscillating electric field, paired with a (perpendicular) magnetic field, and nothing else (according to classical theory). In a plane monochromatic wave, both are perpendicular to the direction of propagation. The optimal value the electric field attains in a half cycle is the wave's amplitude.
This is the classical wave theory that results from Maxwell's equations (which themselves follow from the electrostatics etc. you may be familiar with, Gauss's Law, Faraday induction, Coulomb's Force etc.)
In this theory, the energy of light can be calculated from its amplitude. With quantum theory, the same energy can be counted as Nhv. So that's why the number of photons is practically equivalent to the wave's electric field amplitude. The two different theories are compatible.
Thanks
Yes, I'm starting to get it now and I've seen the perpindicular electric and magnetic wave propagation diagram before, but the one thing I don understand is:
I don't understand how light is the occilation of an electromagnetic Field...
I've always understood it as electromagnetic radiation.
Why do you think the two concepts are incompatible? ("oscillation of electromagnetic field" versus "electromagnetic radiation")
The reason I'm asking is that I suspect that you don't completely understand one concept or the other. If you can state as specifically as possible, why you think there's a problem, it will be easier for someone to clear things up for you.
I didn't say they weren't compatible, I just don't understand how they are. But here's what I think.
2 charged particles at distance r create a force and electric/magnetic potential between them, through space. So this it the electromagnetic field. Now as soon as these particles begin to interact (exert Coulomb's force) then they occilate the electromagnetic field creating electromagnetic radiation?
Is that right?
Also, I'm guessing that the frequency of the wave is dependent on the strenght of the charge, but physically, why is it that as charged particles repell/attract, electromagnetic radiation is emmited?
Hi DB,
The amplitude of a wave can varie even in vacuum. Firstly, it depends on the source shape.
If you have a point source, then the primary energy transferred through any closed surface that contains the source inside must be the same. So,
[tex]A^2*4\pi R^2=const[/tex]
and you obtain in this case
[tex]A prop \frac{1}{R}[/tex]
(please read prop as "proportional" - I don't find its LaTex symbol now)
In the case of a plane wave, yes, the amplitude is constant in vacuum. The amplitude of a wave may change because of dispersion too. But there are 2 types of dispersions and I don't think your question is related with.
thanks clive, though wat is R?
You're welcome DB!
[tex]R[/tex] is the distance from the source to the point where [tex]A[/tex] is evaluated. So,
[tex]A(R) \varpropto \frac{1}{R}[/tex]
(I found [tex]\varpropto[/tex] :smile:)
1. What is light wave amplitude?
Light wave amplitude refers to the maximum displacement or height of a light wave from its resting position. It is a measure of the energy carried by a light wave.
2. How does the amplitude of a light wave vary?
The amplitude of a light wave can vary in different ways, depending on the source and medium through which it is traveling. For example, in a vacuum, the amplitude of a light wave remains constant, but in a material medium, it can decrease due to absorption or scattering.
3. What factors affect the amplitude of a light wave?
The amplitude of a light wave can be affected by the intensity of the light source, the distance the light travels, and the properties of the medium through which it passes. Additionally, the wavelength of the light can also impact the amplitude of the wave.
4. How is light wave amplitude related to length?
The amplitude of a light wave is not directly related to its length. However, the length of a light wave can affect its amplitude indirectly. For example, in a material medium, the length of the light wave can impact how much it is absorbed or scattered, which can in turn affect its amplitude.
5. Why is understanding light wave amplitude important?
Understanding light wave amplitude is important because it helps us to understand how light behaves and interacts with different mediums. It also plays a crucial role in various technologies, such as optics, telecommunications, and medical imaging.
  • Classical Physics
