Light with Gravity and Mirrors
Naty1
I was just looking at how a gravitational mass bends/curves light:
A sketch is at:
http://www.mathpages.com/rr/s6-03/6-03.htm
(It resembles spaghetti being turned on a fork...!)
This is eerily similar to a mirror bending/reflecting light without the influence of any gravity.
Each enables us to see behind an object...as does "gravitational lensing" does; looks like some light is bent 180 degrees...turned around...
What else bends light?:
Does an an electromagnetic field ??;ie, a charged particle?...I think "no" because the EM field is not self interacting as is the gravitational field? But then how did cosmic opaqueness clear following the "bang" (big or bounce or quantum)...straight line collisions between photons and ions?
How about an accelerating observer?
Strong nuclear force?
Going from one optical density to another (prism, for example; or a glass of water) does for sure...
What other phenomena curve/bend light?
Would any of these also work for the strong force, also mass zero? so what??
Are there hints hidden in these interactions regarding the nature of light?? other than wave/particle dualities...??
(I am clearly spending too much time on this forum!)
Light can bend relative to an accelerating observer.
I was curious to see what happens here so I did a calculation (in Rindler coordinates) for a uniformly accelerating observer in flat spacetime. Light that is emitted from the observer in a direction perpendicular to the acceleration follows a curve (relative to the observer) that is, in fact, the arc of a circle of radius c^2/a, heading towards, but never quite reaching, the event horizon at a perpendicular distance of c^2/a behind the observer. This is somewhat surprising because in relativity you usually expect to get hyperbolas instead of circles or parabolas.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
