Why Doesn't Lightning Pull the Cloud to the Ground?
  • Thread starter Thread starter gabby989062
    Lightning
Lightning occurs due to the induction of opposite charges between clouds and the ground. While the Earth does attract the cloud, this force is minimal and insufficient to pull the cloud down significantly. The phenomenon of hair standing on end before a lightning strike indicates the presence of a strong electric field. This electric field can create a potential difference that leads to lightning. Ultimately, the interaction between the cloud and the ground is complex, but the attraction does not result in the cloud being pulled to the ground.
gabby989062
We were reading about lightning and how the cloud has a different charge than the ground. We know that lightning happens because of induction. But if the charges are different, why doesn't the Earth pull the cloud to the ground, or repel it higher into the air?
It wouldn't repel the cloud, since the charges are opposite; but it does attract the cloud, although it is a very small movement. More noticeable might be your hair standing up straight up on end just before the bolt strikes...if it does, you're in big trouble...crouch low, click those heels together, block your ears, ...and pray:wink: ...
