Limit Indeterminate Forms
  • Thread starter whatlifeforme
  • Tags
    Forms Limit
Good. Also, if you want the + to be a subscript, just use ^, as follows: \lim_{x \to 0^+ } = \lim_{x \to 0^+ }.
whatlifeforme
219
find the limit.
[itex]limit_{x->0+}[/itex] [itex](x+1)^{cotx}[/itex]
this is of the form [itex]1^{∞}[/itex]
y = [itex](x+1)^{cotx}[/itex]
lny = cotx * ln(x+1)
not sure if this is correct so far.. and what to do next? somehow turn it into a fraction, perhaps?
whatlifeforme said:
find the limit.
limit x->0+ [itex](x+1)^{cotx}[/itex]
Yes, it's fine so far. And sure, turn it into a fraction so you can apply l'Hopital. If you have a*b you can turn it into a fraction by writing it as either a/(1/b) or b/(1/a). Which looks easier?
[itex]\frac{cotx}{\frac{1}{ln(x+1)}}[/itex] = [itex]\frac{(1/0)}{(1/0)}[/itex]
[itex]\frac{-(cscx)^{2}}{\frac{1}{1/(x+1)}}[/itex] = [itex]\frac{1/0}{(1/(1/1)}[/itex]
or written in another form as:
[itex]\frac{-(cscx)^{2}}{\frac{1}{1/(x+1)}}[/itex] = [itex]\frac{\frac{1}{0}}{\frac{1}{\frac{1}{1}}}[/itex]
is that ∞/1 ??
am i correct so far. do i need to apply l'hopitals again, or is my answer correctly ∞.
is that ∞/1 ??
make that -∞.
whatlifeforme said:
make that -∞.
You picked the hard way to do it and then you did it wrong. Try ln(x+1)/(1/cot(x))=ln(x+1)/tan(x). That's the easy way. Work it out that way, then look back and figure out what you did wrong.
Edit: You forgot to use the chain rule in your second step. I'd just do it over put tan(x) in the denominator.
Also, keep the limit in there. 1/0 isn't defined.
[tex]\lim_{x->0+}\frac{ln(x+1)}{tanx} = \frac{0}{0}[/tex]
[tex]\lim_{x->0+}\frac{\frac{1}{x+1}}{(secx)^{2}} = \frac{1}{1}[/tex]
Hence? Conclusion for the original limit?
Mod note: I made the changes suggested below.
Instead of writing limit_{x->\infty}, you should write "\lim_{x\to\infty}"
Also, if you write "tex" instead of "itex", everything will look better. Only use "itex" for when you aren't starting a new line for math.
Going back to the beginning of the problem, you wrote that ln(y) was equal to the expression you just derived. So what is y?
[itex]\lim_{x\to0+} (x+1)^{cotx}= \lim_{x\to0+} f(x) = \lim_{x\to0+} e^{lny}[/itex]
[itex]= e^{1} [/itex]
Right.
Looks good. Instead of writing "itex", though, it'll look better with "tex"
You could also just use "##" at the beginning and end of whatever you want to type in latex.
I would add to the OP that you don't need to have flocks of itex or tex tags - one at the beginning and the closing tag of that type at the end of the line.
## at beginning and end - same as itex at beginning and /itex at end.
$$ at beginning and end - same as tex at beginning and /tex at end.
whatlifeforme said:
y = [tex](x+1)^{cotx}[/tex]
lny = cotx * ln(x+1)[tex]\lim_{x\to0+} (x+1)^{cotx}= \lim_{x\to0+} f(x) = \lim_{x\to0+} e^{lny}[/tex]
[tex]= e^{1}[/tex]
**note:updated with tex.
[tex] \lim_{x \to 0^+ } [/tex]
1. What are limit indeterminate forms?
Limit indeterminate forms are mathematical expressions that cannot be evaluated directly, as they result in an undefined or infinite value. These forms typically involve ratios or differences of two quantities that both approach zero, infinity, or an undefined value.
2. How do you determine if a limit is an indeterminate form?
To determine if a limit is an indeterminate form, you must evaluate the limit expression and analyze the resulting value. If the value is undefined, such as 0/0 or ∞/∞, then it is an indeterminate form. Other common indeterminate forms include 0*∞, ∞-∞, and ∞/0.
3. Why are indeterminate forms important in calculus?
Indeterminate forms are important in calculus because they represent situations where traditional mathematical methods cannot be directly applied. These forms often arise when solving for limits, which are used to determine the behavior of a function as it approaches a specific value or point. Understanding indeterminate forms is crucial in finding accurate solutions to complex problems in calculus.
4. How do you solve for limits involving indeterminate forms?
Solving for limits involving indeterminate forms requires the use of advanced techniques such as L'Hôpital's rule, which allows you to differentiate both the numerator and denominator of the limit expression to obtain a new expression that may be easier to evaluate. Other methods include factoring, substitution, and using trigonometric identities to simplify the expression.
5. Can all indeterminate forms be solved?
Not all indeterminate forms can be solved using traditional mathematical methods. Some forms, such as ∞-∞ and 0*∞, may require more advanced techniques or may not have a finite solution. In some cases, the limit may not exist or may be undefined. It is important to carefully analyze the expression and use appropriate methods to determine if a solution can be found.
9K
