Limit of (1 - cosh(2x)) / 4x^3 + x^2
  • Thread starter Thread starter username12345
    Limit
9 replies · 4K views
username12345
[tex]\mathop {\lim }\limits_{x \to 0 } \frac{1 - cosh(2x)}{{4x^3 + x^2}}[/tex]
Product, sum, quotient laws
[tex]\mathop {\lim }\limits_{x \to 0 } \frac{1 - cosh(2x)}{{4x^3 + x^2}} = <br /> \mathop {\lim }\limits_{x \to 0 } \frac{\lim 1 - \lim cosh(2x)}{{\lim 4 + \lim x^3 + \lim x^2}}<br /> = <br /> \mathop {\lim }\limits_{x \to 0 } \frac{1 - \lim cosh(2x)}{{4 + 0 + 0}} <br /> = <br /> \mathop {\lim }\limits_{x \to 0 } \frac{1 - cosh(\lim 2x)}{{4}}<br /> = <br /> \frac{1 - cosh(0)}{{4}}<br /> = \frac{1 - 1}{{4}}<br /> = 0[/tex]
However the answer is supposed to be 2.
I was sure the denominator should be 4, but not sure how to get 8 in the numerator :confused:
Okay well, You seem to have changed that 4x^3 to 4 + x^3, which is how you got your zero denominator to be 4.
Firstly, do you know [tex]\lim_{x\to 0} \frac{ \sinh x}{x}[/tex] ? That is a good thing to know and is easy to find.
Also, can you express [tex]\cosh 2x[/tex] in terms of sinh^2 x ? That will help.
sinh(0) = 0 so use LHopitals rule :
[tex]\lim_{x\to 0} \frac{ \sinh x}{x} = \lim_{x\to 0} \frac{ \cosh x}{1} = \frac{cosh 0}{1} = \frac{1}{1} = 1[/tex]
I don't know what you mean, sorry.
Ok well, have you seen the identity
[tex]\cosh 2x = 2\sinh^2 x +1[/tex]
I tried subbing x = 0 into the above in the original equation and get:
[tex]\frac{1 - 2e^2 + 4 - \frac{2}{e^2}}{16x^3 + 4x^2}[/tex]
Now should I divide each term by [tex]x^3[/tex]?
Can someone please show me the method? I am getting confused now.
Directly substitute that identity into your limit, and apply the other limit you worked out.
You mean into this? [tex]\mathop {\lim }\limits_{x \to 0 } \frac{\lim 1 - \lim cosh(2x)}{{\lim 4 + \lim x^3 + \lim x^2}}[/tex]
so, [tex]\mathop {\lim }\limits_{x \to 0 } \frac{\lim 1 - \lim 2 + \lim sinh^2(x+1)}{{\lim 4 + \lim x^3 + \lim x^2}} = \frac{1 - 2 + \lim sinh^2(x+1)}{4}[/tex]
I can't get that to equal 2.
Hey dude apply l-hospital rule when there is 0/0 form after putting x=0 in the original equation , now differentiate the equation not in u/v form differentiate upper equation and lower equation differently until u got the equation not in the form 0/0 after putting the value
First use L'Hopital's rule with the original problem and keep using it until you're done. You probably want to use an identity to make differentiation a little easier after one step.
Best answer I can get is 1/2 or -1/2.
Anyway test on this starts in 45 minutes so just hope this question doesn't come up.
