Limit of sin(3x)/π-x as x approaches π
  • Thread starter Thread starter Pithikos
    Limit
The problem involves evaluating the limit of sin(3x)/(π-x) as x approaches π, which falls under the subject area of calculus, specifically limits and trigonometric functions.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to rewrite the limit by substituting t for π-x, leading to a new expression. Some participants suggest considering different cases based on the value of n, while others mention the possibility of applying L'Hôpital's rule, although one participant notes that they have not learned this method yet. There is also a discussion about the properties of the sine function and its behavior near the limit point.
The discussion is ongoing, with participants exploring various approaches to the limit. Some have provided insights into the sine function's properties, while others are focused on finding a method that aligns with their current learning. There is a recognition of different interpretations and attempts to clarify the problem setup.
Participants note that they have only been working with standard limits and are looking for a solution that does not involve advanced techniques like L'Hôpital's rule. There is also mention of confusion regarding the notation used in the problem.
Pithikos
lim of sin(3x)/π-x as x->π
I tryied replacing π-x with t so t=π-x and rewrote the whole limit as:
lim of sin(3(π-t))/t as t->0
that gives me(without the lim notation):
sin(3π-3t)/1 * 1/t
then I noticed that if I multiply the dominators and numerators with 3π-3t it doesn't help much because replacing t with 0 in (3π-3t) doesn't give 0 so therefore can't use the standard limit lim sinx/x -> 1 as x -> 0
I have been stuck with this problem 2-3 days now. I made some other mistakes in the first tries not worth mentioning. Now it seems I took the right way into the problem but I just feel stuck :/
Well, you should discriminate cases:
1) n=0, then you can use that sin(x)/x --> 1
2) n is not 0, then you will have to do something else... But in this case, we got a "number/0" situation, so this would give positive or negative infinity...
Since for x = pi => sin(3pi) = 0 and pi - pi = 0 one can apply I'Hopital's rule by differentiating the top and the bottom expressions.
Thing is that we haven't learned the L'Hopital's rule so for the exercise there must be some more "caveman" way to do this. We have only been working with standard limits like the following.
limits of x approaching 0 :
sinx/x -> 1
tanx/x -> 1
ln(1+x)/x -> 1
.. etc.
I think a previous poster thought the π symbol was the variable n.
First note that
[tex]\sin(3x) = \sin(3x - 3\pi)[/tex] so
[tex]\frac{\sin(3x) }{\pi - x}=\frac{\sin(3x-3\pi) }{\pi - x}[/tex]
Can you get it from there?
Thank you! Now I solved it :!)
Though instead of sin(3x-3π) I used sin(3π-3x) so it became:
sin(3π-3x)/3π-3x * 3/1 =
1 * 3
Btw with what tool do you write equations in that mathematical way?
1 * 3Btw with what tool do you write equations in that mathematical way?
Of course, you need a minus sign. The math is LaTeX using the tex tags. Click on an expression to see how it's written.
See https://www.physicsforums.com/misc/howtolatex.pdf
Actually, 3 is correct.
[itex]\sin(3x) = -\sin(3x - 3\pi) = \sin(3\pi - 3x)[/itex]
This makes sense when you think about it: subtracting 3π is essentially the same as rotating the unit circle one half-turn (in either direction), so the sine function would have to change sign (pun not intended).
  • · Replies 21 ·
