Limit of the solution of a differential equation
The discussion revolves around a differential equation of the form \(\frac{dy}{dt} + a(t)y = f(t)\), where \(a(t)\) and \(f(t)\) are continuous functions. The problem requires showing that the limit of the solution \(y(t)\) approaches 0 as \(t\) approaches infinity, given that \(a(t) > c > 0\) for all \(t\) and \(\lim f(t) = 0\).
  • Participants explore the application of limits to the differential equation and discuss the implications of the conditions on \(a(t)\) and \(f(t)\). There are questions about the existence of limits for \(y\) and \(y'\), and whether certain cases, such as \(y\) approaching infinity, are possible. Some participants suggest that the intuition behind the behavior of \(y(t)\) can be understood by considering the signs of the derivative based on the positivity of \(a(t)\) and the limit of \(f(t)\).
The discussion is ongoing, with participants sharing their thoughts and intuitions about the problem. Some guidance has been offered regarding the behavior of the solution and the implications of the limits, but there is no explicit consensus on the approach or resolution yet.
Participants note the importance of the conditions imposed on \(a(t)\) and \(f(t)\) and question how these affect the limits of \(y\) and \(y'\). There is also mention of the need for rigor in the intuitive explanations provided.
Ressurection
Given the differential equation : [itex]\frac{dy}{dt}[/itex] + a(t)*y = f(t)
in which a and f are continuous functions in ℝ and verify:
a(t) > c > 0 [itex]\forall[/itex]t , lim f(t) = 0
Show that any solution of the differential equation satisfies:
lim y(t) = 0
My first thought was to apply the limit to the equation right away, so that would give me
lim (y') + lim(a) * lim(y) = 0
Now this means both the limits of y and y' must exist, and since a(t) > c > 0, either they are both 0 or one is positive and the other negative.
When lim y is a finite constant, then lim y' = 0, which only allows for the case of both limits being 0. (Side note: does lim y being finite imply that lim y' = 0?)
When limit y is +∞, this would require limit y' = -∞. Is this case possible?
My intuition tells me it isn't, but I'm not absolutely sure..
Also, if lim (a) = ∞, then I don't see any restriction that imposes lim y = 0, which makes me believe there may be a more simpler way to solve this problem.
Note: All limits refer to t → ∞.
I think the intuition goes something like this:
[tex]\frac{dy}{dx} = -a(t)y(t) + f(t)[/tex]
OK, so [itex]a(t)>0[/itex] all the time, and [itex]\lim f(t) = 0[/itex]. So, if [itex]y(t)<0[/itex], then the derivative is positive (let's assume [itex]f[/itex] is zero for the intuition, but you're going to have to mention the fact that its limit is zero but it is not zero) and if [itex]y(t)>0[/itex] then the derivative is less than zero. So, basically, if [itex]y[/itex] is positive, it is going down, and if [itex]y[/itex] is negative, it is going up. Now, that's just the intuition, so you will have to clean it up to make it rigorous (depending on how rigorous you need to make it.) But, do you understand the general idea?
lim y(t) = 0
Hello Ressurection. Welcome to PF !
Consider the function [itex]\displaystyle g(t)=\frac{\sin(t^2)}{t}[/itex].
[itex]\displaystyle \lim_{t\to\infty}\,g(t)=0\ .[/itex]
[itex]\displaystyle g'(t)[/itex] oscillates between -2 & 2 with increasing frequency as t → ∞.
I think I do, because when taking the limit, the only 2 possibilities that satisfy that relation are:
- the limits do not exist (which would be the case of a sine or cosine)
- the limit is 0, which is the point that prevents the function from oscillating
SammyS said:
Hello Ressurection. Welcome tom PF !
That's a nice example, but taking the limit of the differential equation proves that the 2 limits must exist doesn't it? In that case, the limit of g' does not exist.
Sorry for the mess that my first post may be, I have zero experience regarding TeX
Try integrating factor.
I believe that you are correct in that if the two limits exist and y(t) → 0, then also y'(t) → 0 .
You'll get the hang of using TeX.
What you wrote was pretty clear.
  • · Replies 19 ·
