Limit (sin(4x)/sin(6x)) as x->0
  • Thread starter Thread starter adamjts
    Limit
The discussion revolves around evaluating the limit of the expression (sin(4x)/sin(6x)) as x approaches 0, within the context of introductory calculus. Participants are encouraged to find a solution without employing L'Hospital's rule.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the need to rewrite the limit expression in a form that allows the application of the known limit (sin(x)/x) as x approaches 0. There are attempts to manipulate the expression by factoring out terms related to sin(4x) and sin(6x). Some participants question the steps taken to arrive at the limit and suggest corrections to ensure proper application of the limit properties.
The discussion is active, with participants exploring different approaches to solve the limit problem. Some guidance has been offered regarding the correct form needed to apply the limit, while others have reiterated the importance of not using L'Hospital's rule. There is a mix of interpretations regarding the steps to take, but no consensus has been reached on a final method.
Participants are reminded that the problem must be solved without using L'Hospital's rule, which has led to some confusion and varied approaches in the discussion.
adamjts
Hi all,
I'm just beginning calculus and I'm having trouble figuring this one out.
I need to solve this one without using l'hospital's rule.
Find
We know that limit (sin(x)/x) as x -> 0 equals 1
Thanks! Much appreciated!
adamjts said:
Hi all,
Find
In order to use the limit you now, you must rewrite the expression so that you have a factor
[itex]\frac{\sin(4x)}{4x}[/itex] right? And you need to rewrite the [itex]\frac{1}{\sin(6x)}[/itex] in what form?
OH. so i'd go
= limit (sin(4x)/1) * Limit (1/sin(6x))
= Limit (4sin(4x)/4) * Limit (6/6sin(6x))
= 4/6
=2/3
Yeah?
adamjts said:
OH. so i'd go
= 4/6
=2/3
Yeah?
Almost! You need to get [itex]\frac{\sin(4x)}{4x}[/itex] in order to take the limit, not
[itex]\frac{\sin(4x)}{4}[/itex]. And same thing for the sin(6x).So you need to correct one step. But your final answer is correct. Good job!
This can be done by
L HOSPITAL's rule
Differentiate with respect to x on denomenator and numerator and you get the answer
Ans is 2/3
Midhun said:
This can be done by
L HOSPITAL's rule
The question asks to NOT use L'Hospital's rule. Which is why I suggested this approach.
  • · Replies 18 ·
13K
