What is the Locus of Points on a Circle Touched by a Given Line?
  • Thread starter Thread starter Raghav Gupta
    Circle Line
The discussion revolves around determining the locus of points (h,k) on a circle defined by the equation x² + y² = a², when touched by a line given by hk + ky = 1. Participants initially debate whether the line's equation is correct, with some suggesting it should include x. After analyzing the equations, it becomes clear that the locus is not a circle but rather two points, specifically y = ±a, indicating that the original line equation may have been a typo. Ultimately, the correct formulation leads to the conclusion that the locus of points (h,k) is a circle with a radius of 1/a, derived from the discriminant of the quadratic equation. The conversation highlights the importance of understanding the geometric relationships between the line and the circle.
Raghav Gupta
If the line ## hk + ky = 1 ## touches the circle ## x^2 + y^2 = a^2 ##, then locus of the points (h,k) is a circle of radius :
a
h
k
1/a
NA
Tried differentiating circle equation (Is differentiation of use here?, also don't know if it is a calculus or pre-calculus problem. )
Got y' = -x/y
Differentiated line equation and thinking h,k are constants which is not true I got y' = 0
I have to substitute something but what?
Make a drawing !
You know the slope of the line, you know an equation for a point it has to go through.
And you probably have a typo in the equation for the line ?
BvU said:
Make a drawing !
No, I have not a typo in equation of line.
The question is confusing me as I think there should be x in equation of line?
Now it says ##y={1\over k}-h## having slope zero. Touches the circle if ...
Not getting, are you saying I have a typo in Question statement of line equation?
That is what I said and that is what I typed. ##
hk + ky = 1## is the equation for a horizontal line. Slope 0. Does it say that in the exercise you were given ?
Oh, so you are seeing my attempt?
Raghav Gupta said:
Differentiated line equation and thinking h,k are constants which is not true I think I got y' = 0
The exercise says only the problem statement.
Can we please agree that the exercise text states ##hk + ky = 1## as the equation of the line ? If so, we can proceeed and prove that the locus of the points (h,k) is not a circle.
BvU said:
Can we please agree that the exercise tekst states ##hk + ky = 1## as the equation of the line ? If so, we can proceeed and prove that the locus of the points (h,k) is not a circle.
Yeah we can agree.
Now how to proceed?
Is it hk+ ky= 1 or hx+ ky= 1?
In post #9 Raghav repeats hk+ ky= 1 and now we are under way to discover that that does NOT give a circle as locus. Read !
y = a or y = -a.
So the question is wrong as locus is not a circle but mere two points.
Not the way it works. You are asked for the locus of the points (h,k), not for the points (x,y) where the line touches the circles.
To make a long story short: ##y=\pm a## is correct as the equation for the tangent line. If you want to write that as ##hk + ky = 1## you get e.g. ##hk + ka = 1## so the points (h,k) satisfy ##k = {1\over h+a}## which is not the equation of a circle.
Having delivered proof that ##hk + ky = 1## is not what was intended for this exercise, I propose you now accept that it should have been ##hx + ky = 1##.
What do we know about these lines ?
Well, as you already found in post #1, they have slope -x/y . Also, one of the points on the line satisfies ##x^2+y^2 = a^2##. So what do we have to impose on h and k to make the equation for such a line take the form ##hx + ky = 1## ?
(My advice: draw a circle and a tangent :rolleyes: !)​
Took a point on line x1,y1
Then slope is - x1/y1.
x12 + y12 = a2
Also hx1 + ky1 = 1.
Here is a circle of radius a and some random 2 tangents drawn.
Good start. The point where the line is tangent to the circle is (x,1y1).
Now (important step): what's the equation of the line ? (I don't mean hx1 + ky1 = 1 but the equation for the line in therms of x1, y1 and a)
I was doing some manipulations,
Take the general equation
## hx + ky = 1 ##
## ⇒ y = \frac{1-hx}{k} ##
In equation ## x^2 + y^2 = 1 ##
Substituting y value as it satisfies,
## x^2 + \frac{1+ h^2x^2 -2hx}{k^2} = a^2 ##
Rearranging,
## x^2( k^2 + h^2) - 2hx +1 - k^2a^2 = 0 ##
It striked to me that
Now discriminant of quadratic equation should be zero as tangent line touches one point.
## 4h^2 - 4 (k^2 + h^2)(1-k^2a^2) = 0 ##
Solving we get,
## k^2 + h^2 = 1/a^2 ##
So locus is circle of radius 1/a
What was the use of diagram here and calculating slope earlier as -x/y ?
LIne segment from origin to (x1, y1) has length a.
Tangent line in (x1, y1) is perpendicular to that line.
That means all points (x,y) on that tangent line satisfy $$ (x_1,y_1)\cdot(x, y) = a^2$$ -- an inner product, written out : $$x_1 x + y_1 y = a^2$$ -- and there's your tangent line equation without any quadratic equation at all !
Compare $$x_1 x + y_1 y = a^2 \quad {\rm to} \quad x + k y = 1$$ and you see
$$h = x_1/a^2 \quad {\rm and} \quad k = y_1/a^2$$
Since $$ x_1^2+ y_1^2 =a^2$$ you indeed find
$$ h^2+ k^2 =1/a^2$$
Well done !
I hope you are now also convinced that the line equation in post #1 was a typo :wink:?
Oh, another and easy way
That means all points (x,y) on that tangent line satisfy $$ (x_1,y_1)\cdot(x, y) = a^2$$ -- an inner product, written out : $$x_1 x + y_1 y = a^2$$ -- and there's your tangent line equation without any quadratic equation at all !--
Not getting this
Have you ever heard of the normal equation for a straight line ? We learned it at school (I was 15 then...).
It goes like this:
For all points on the dashed tangent: Inner product $$(x,y) \cdot\ (x_1, y_1) = \vec v_1 \cdot \vec v_2 = |\vec v_1 |\;|\vec v_2| \;\cos\phi = |\vec v_1 |\;|\vec v_1|/ \cos\phi \;\cos\phi = |\vec v_1 |^2$$
Note that this time the arrows aren't for infinite lines but for vectors.
There is also a unit normal vector form: if ##\tan \alpha = y_1/x_1## (hey, that's like (-x_1/y_1) -1 !)
you have with ##\vec n = (x_1, y_1), \quad \hat n = (\cos\alpha, \sin\alpha) = (x_1, y_1) / |\vec v_1| ## that $$ x\cos\alpha + y\sin\alpha = |n| \quad {\rm or} \quad \vec v \cdot \hat n = |\vec n|$$
Yeah, :wink::wink: ( The typo was by the book ,not by me):biggrin:
It goes like this:
I have not read that form earlier but now see it is fast as compared to quadratic.
Thanks.
It goes like this:
Very nice drawing! What software package did you use to draw it?
Thank you for the compliment; that was MS Visio.
It goes like this:
Hey what angle ## \alpha ## is here in diagram?
I understood your dashed tangent inner product but not that unit vector normal form.
##\tan\alpha = y_1/x_1##
This unit vector normal form simply removes one factor ##|\vec n|##.
Likes Raghav Gupta
