Line Integral over Vector Field?
taylormade
Not exactly a homework problem, a problem from a sample test. I'm boning up for my qualifying exam.
Consider the vector field:
F = (ax + by)i + (cx + dy)j
where a, b, c, d are constants.
Let C be the circle of radius r centered at the origin and going around the origin one turn in the mathematically positive direction starting from the positive x-axis.
A parameterization for C is x = r cost y = r sint, (z=0), Where 0\leq t \leq 2 \pi
Find the integral \int_{C}F.dR for any values of a, b, c, d (the answer may depend on a, b, c, d)
The rust is killing me. I remember that I need line integrals to solve the problem, but the setup isn't coming out of the fog.
In terms of your parametrization C, dR is (-r*sin(t)dt,r*cos(t)dt). Do you see why? Now express the vector F in terms of t and take the dot product. You'll wind up with two integrals dt to do. Any clearer?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
