Linear actuators for mechanical project
The discussion focuses on finding suitable linear actuators for a project requiring fast operation controlled by an Arduino UNO. Key specifications include a minimum speed of 100 mm/s and a load capacity of at least 5 kg, with a control frequency of approximately 10 Hz. Suggestions include potentially overvolting certain actuators from ServoCity to achieve the desired speed and contacting them for further recommendations if continuous operation is needed. A specific actuator from Firgelli Auto is mentioned as a potential fit, along with wiring options using DPDT relays or high-current analog switch ICs for control. The conversation emphasizes the importance of matching actuator specifications to project requirements.
aortucre
Hey guys, I was wondering if you could help me out here. I'm working on a project that needs two fast linear actuators which I'm planning to control with the Arduino logic board, but I can't seem to find anything that suits what I need. Here are the specs.
-Type of actuator: Linear
-Minimum acceptable speed: 100 mm/s
-Minimum acceptable load: 5kg
-Input: Signal from Arduino UNO logic board
-Frequency: Approx 10 Hz
I would appreciate any help that you guys could give me. All the actuators that I've found online are either too weak or too slow.
Dependent on the duty cycle required you could possibly overvolt http://www.servocity.com/html/25_lbs__thrust_linear_actuator.html
these @ 24VDC and get the 100mm/sec required.
If the actuators need to run more than intermittently, I would contact ServoCity about their recommendations. They've been easy to work with for this sort of thing in my experience.
Max travel?
Jupiter6 said:
Max travel?
Around 18"
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
