Linear algebra, eigenvectors and eigenvalues
ann.r221
If v is an eigenvector of an invertible matrix A, which of the following is/are necessarily true?
(1) v is also an eigenvector of 2A
(2) v is also an eigenvector of A^2
(3) v is also an eigenvector of A^-1
A) 1 only
B) 2 only
C) 3 only
D) 1 and 3 only
E) 1,2 and 3
I am pretty sure 2 is true because if we look at Av = (lamba)v.
A^2v = A(lambda)v = (Av)(lambda) = (lambda)v(lambda) = (lambda)^2 v
So A^2v = (lambda)^2v. So that should be that v is an eigenvector for A^2 as well. I am not sure about the others can someone help?
You did so well on b), isn't a) just as easy? (2A)v=? For c) use A^(-1)A=I.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
