Linear algebra: Prove that the set is a subspace
The discussion focuses on proving that the set U of all commuting matrices with the matrix A = \begin{bmatrix} 2 & 0 & 1 \\ 0 & 1 & 1 \\ 3 & 0 & 4 \\ \end{bmatrix} is a subspace of \mathbb{M_{3\times 3}}. It is established that U is defined as U = \{B \in \mathbb{M_{3\times 3}}: AB = BA\}, and it is confirmed that U contains the span\{I, A, A^2, ...\}. The dimension of U is determined to be 3, with a basis consisting of the column vectors of the identity matrix. The discussion also addresses the correct interpretation of basis and dimension in the context of matrix spaces.
  • Understanding of commuting matrices
  • Knowledge of subspaces in linear algebra
  • Familiarity with vector space span
  • Concepts of basis and dimension in vector spaces
  • Study the Cayley-Hamilton theorem and its applications in linear algebra
  • Learn about the properties of matrix commutativity and its implications
  • Explore methods for finding bases and dimensions of subspaces in matrix spaces
  • Investigate the relationship between finite and infinite spans in vector spaces
Students and educators in linear algebra, mathematicians focusing on matrix theory, and anyone interested in understanding the properties of subspaces and dimensions in vector spaces.
gruba
Let U is the set of all commuting matrices with matrix A= \begin{bmatrix}<br /> 2 &amp; 0 &amp; 1 \\<br /> 0 &amp; 1 &amp; 1 \\<br /> 3 &amp; 0 &amp; 4 \\<br /> \end{bmatrix}. Prove that U is the subspace of \mathbb{M_{3\times 3}} (space of matrices 3\times 3). Check if it contains span\{I,A,A^2,...\}. Find the dimension and a basis for U and span\{I,A,A^2,...\}.
-Commuting matrices
-Subspaces
-Vector space span
Basis and dimension
U can be defined as U=\{B\in\mathbb{M_{3\times 3}}: AB=BA\}.
Letting B=\begin{bmatrix}<br /> a &amp; b &amp; c \\<br /> d &amp; e &amp; f \\<br /> g &amp; h &amp; i \\<br /> \end{bmatrix} and solving the equation AB=BA gives B=\begin{bmatrix}<br /> i-\frac{2}{3}g &amp; 0 &amp; \frac{1}{3}g \\<br /> g-3f &amp; i-3g &amp; f \\<br /> g &amp; 0 &amp; i \\<br /> \end{bmatrix}.
U is a subspace of \mathbb{M_{3\times3}} if \forall u_1,u_2\in U\Rightarrow u_1+u_2\in U,\forall t\in\mathbb{R}\Rightarrow tu_1\in U which is correct.
It is easy to check that if C\in span\{I,A,A^2,...\}\Rightarrow C\in U:
Linear combination for C is
C=c_0I+c_1A+c_2A^2+...\Rightarrow CA=AC\Rightarrow C\in U
U has the dimension 3 and a basis are column vectors of identity matrix 3\times 3.
How to find the dimension and a basis for span\{I,A,A^2,...\}?
-Commuting matrices
-Subspaces
-Vector space span
Basis and dimension
What does it mean to be a basis?
I don't agree with your explanation of the dimension and basis of U. Column vectors (in this case) are ##3x1## matrices. You're claiming that you can generate a whole space of 3x3 matrices with linear combinations of 3x1 matrices. The basis that you are claiming is not even a subset of U.
Also, how are you getting B?
I made a mistake in the statement for the dimension and a basis of U. You could look at 9\times 1 vectors.
But what is the way of algebraically finding a basis (dimension follows) of U and span\{I,A,A^2,...\}?
Matrix B can be reduced from 9 to 3 variables after solving the equation AB=BA (too long to post).
Your basis has to be a set of 3x3 matrices.
That is fair, I'm just wondering the method you used.
You've (assuming your calculations are correct) found what matrices in the subspace U "look like". Can you write that matrix as a linear combination of other matrices? (I haven't verified, but it seems like the ##span\{I,A,A^2, \dots\}## would not have been given to you just to show that it was contained in U.
I think that it is not possible to form a linear combination on span\{I,A,A^2,...\} because this set is not finite - defined (you could arbitrarily choose that span\{I,A,A^2,A^3\} - this would be finite set).
What can you say about the dimension of span\{I,A,A^2,...\}?
I don't follow what you are trying to say here.
I'm sorry, I must be missing something.
(a) The space spanned by an infinite set can nevertheless be finite-dimensional; as a trivial example, consider \mathrm{span}\{ (x,0) : 0 &lt; x \leq 1\} which is just the one-dimensional subspace of \mathbb{R}^2 spanned by (1,0).
(b) In this case, apply the Cayley-Hamilton theorem.
A linear combination on an infinite set is defined to be a linear combination on a finite subset so your objection in post 5 is not relevant.
