Linear Algebra - REF with another variable
The discussion revolves around determining the values of a for which a given system of linear equations has no solutions, a unique solution, or infinitely many solutions. The equations are presented in an augmented matrix format, and participants are exploring the implications of manipulating this matrix.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss switching rows in the augmented matrix and performing row operations to simplify the system. There is confusion about how to manipulate specific entries to achieve desired forms, particularly in relation to the variable a. Questions arise regarding the conditions under which the system will have different types of solutions.
The discussion is active, with participants providing guidance on performing row operations and correcting arithmetic errors. There is an ongoing exploration of how to derive conditions for unique, no, or infinitely many solutions based on the value of a, though no consensus has been reached yet.
Participants are working under the constraints of a homework assignment, which may limit the methods they can use. There is also a focus on ensuring that the final form of the augmented matrix adheres to specific criteria for determining the types of solutions available.
Schaus
Determine the values of a for which the following system of linear equations has no solutions, a unique solution, or infinitely many solutions. You can select 'always', 'never', 'a = ', or 'a ≠', then specify a value or comma-separated list of values.
x1−2x2+2x3 = −1
−3x1+ax2−10x3 = 5
x1+x2−4x3 = 3
Augmented Matrix
-3 a -10 5
1 1 -4 3
I switched the row with the variable to the bottom.
1 -2 2 -1
1 1 -4 3
-3 a -10 5
I minused Row 1 from Row 2
1 -2 2 -1
0 3 -6 5
-3 a -10 5
3Row 1 + Row 3
1 -2 2 -1
0 3 -6 5
0 (a-6) -4 2
Here is where I get confused. I don't know how to get the 3 in row 2 to equal 1 and get the (a-6) to equal 0.
Any advice as to where I went wrong or what I need to do next would be greatly appreciated!
Let's begin with the augmented matrix:
##\left[\begin{array}{ccc|c}1 & -2 & 2 & -1 \\ -3 & a & -10 & 5 \\ 1 & 1 & -4 & 3 \end{array}\right]##
You switched the 2nd and 3rd rows:
##\left[\begin{array}{ccc|c}1 & -2 & 2 & -1 \\1 & 1 & -4 & 3 \\ -3 & a & -10 & 5\end{array}\right]##
Next, you performed ##R_2-R_1##:
##\left[\begin{array}{ccc|c}1 & -2 & 2 & -1 \\0 & 3 & -6 & 4 \\ -3 & a & -10 & 5\end{array}\right]##
Note: I have corrected an arithmetic error. Next, you performed ##3R_1+R_3##:
##\left[\begin{array}{ccc|c}1 & -2 & 2 & -1 \\0 & 3 & -6 & 4 \\ 0 & a-6 & -4 & 2\end{array}\right]##
What can we multiply the second row by to get the 3 to be a 1?
Divide that row by 3.
Use the determinant! When ##\text{det}[\mathbf{A}]=0## there will be no unique solution.
Let's take FactChecker's advice and perform ##\dfrac{1}{3}R_2##:
##\left[\begin{array}{ccc|c}1 & -2 & 2 & -1 \\0 & 1 & -2 & \frac{4}{3} \\ 0 & a-6 & -4 & 2\end{array}\right]##
Now, obviously, we need to perform ##2R_2+R_1##:
##\left[\begin{array}{ccc|c}1 & 0 & -2 & \frac{5}{3} \\0 & 1 & -2 & \frac{4}{3} \\ 0 & a-6 & -4 & 2\end{array}\right]##
Now, we need to perform ##x\cdot R_2+R_3## such that:
##x\cdot1+(a-6)=0##
What is ##x##, and what do you get after performing the operation?
So I take (a+6)R2-R3?
1 0 -2 ----------- 5/3
0 1 -2 ------------ 4/3
0 0 (-2a-16) -------- ((4/3)a+10)
Sorry for the slow reply, I've been very busy with school.
No, that won't work. In column 2, (a + 6) * 1 - (a - 6) ##\neq## 0.
So I should have multiplied by -(a-6)?
-(a-6)R2+R3
0 0 (2a-16) -------- ((4/3)a-6)
-(a-6)R2+R3
Yes, assuming that your work leading up to this last matrix is correct (I didn't check).
Now, for what value(s) of a will there be a unique solution, no solution, or an infinite number of solutions?
2a-16 = ((4/3)a-6)
a=15
No solution = Never
Unique solution ---- a≠15
Infinitely many solutions--- a=15?
Schaus said:
2a-16 = ((4/3)a-6)
a=15
No solution = Never
No. Where did 15 come from?
A bit more of a hint. Suppose that each of the following was the bottom row of your augmented matrix:
1) 0 0 0 | 5
2) 0 0 0 | 0
3) 0 0 1 | 2
and that the 2nd and 3rd rows had leading entries of 1.
For which of the above 3rd rows would we expect a) a unique solution, b) no solution, c) an infinite number of solutions?
1) No solution
2) Infinitely many solutions
3) One unique solution
I got the a=15 by making 2a-16 = (4/3a-6)
Schaus said:
1) No solution
Yes to all of the above.
That seems like a reasonable thing to do, but it's not. You're not solving the equation 2a - 16 = (4/3)a - 6. Instead, you're trying to make the coefficient of z (what I'm calling the 3rd variable) equal to 1.
In other words, the bottom row of your matrix corresponds to the equation (2a - 16)z = (4/3)a - 6. What do you need to do to turn this into 1z = <something>? In particular, are there any values of a that will cause problems?
