Linear and Non linear HEMT model
  • Thread starter Thread starter Hoque_bd
    Linear Model
Linear HEMT models are used for small-signal analysis, while non-linear models apply to large-signal conditions. The biasing conditions significantly affect the operation and performance of both models. Linear models assume constant parameters, whereas non-linear models account for variations in device characteristics under different biasing levels. This distinction is similar to that found in other transistor technologies like BJT, MOSFET, and JFET. Understanding these differences is crucial for accurate circuit design and analysis.
Hoque_bd
Hi,
What are the differences between linear and non linear HEMT model? What is the relation of biasing to linear and non linear HEMT model?
The difference is exactly the same as linear small-signal vs. nonlinear large-signal with any other transistor technology (BJT, MOSFET, JFET, etc.). Understand that and you have your answer.
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
