Linear/angular Momentum / tripping / conservation
The discussion revolves around the dynamics of a rectangular object sliding on a frictionless surface and its interaction with an obstacle, focusing on the concepts of linear and angular momentum. The object, with mass m and speed V, experiences an impulse I from the obstacle, which alters its linear momentum and induces rotation. Participants debate the appropriate equations to use, with a consensus that angular momentum should be prioritized due to the nature of the impact. There is a specific interest in deriving a formula to determine the speed threshold at which the object will trip over the obstacle. The conversation emphasizes the importance of selecting the correct reference point to simplify calculations involving angular momentum.
timarli
An rectangular object(mass m) sliding on a horizontal plane (surface is frictionless), with a speed V, object height H.
then hits a rectangular obstacle with height h. V is large enough to cause tripping
what is the relation between linear momentum / angular momentum / conservation of momentum
is this what's happening; the object has a momentum of P=mV.
then an impulse I=t*F is applied to the object by the obstacle.
This impulse reduces the linear momentum to P'=m*V-F*x
---This m*V-Fx gives the angular momentum(with respect to the point of contact) causing the rotation?---
I am not sure if my thinking is correct, especially my last statement.
An alternative is; taking initial mV as an angular momentum with changing radius wrt the contact point? ie not mentioning linear momentum at all?
Thanks in advance.
It won't be useful to introduce F or t. Just leave it as I.
x?
I provides the angular momentum.
To solve the problem, you need to use a fact concerning subsequent motion of the block.. like, some point that is stationary immediately after impact.
x?
Thanks a lot haruspex.
x was wrong, well spotted. It should be 't'.
what I am trying to do is derive a formula to show the affect of speed on the tripping.
Assuming the object is a car and the obstacle is a concrete block; I would like to find out what's the speed above which the car will trip. So the top of concrete can be the reference point.
I know the mass, I know the object height and center of gravity and obstacle height. I am still struggling to figure out writing the equation. Not sure if I need to use momentum equations or energy equations.
You need to pick the one that's conserved. There is an unknown impulse at the point of impact, and it clearly does not conserve work. The best, then, is to take angular momentum, picking a reference point that makes the unknown impulse have zero moment.
Likes 1 person
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
