Linear approximation and errors
6 replies · 3K views · last reply
anthonym44
[SOLVED] Linear approximation
Juan measures the circumference C of a spherical ball at 40cm and computes the ball's volume V. Estimate the maximum possible error in V if the error in C is as most 2cm. Recall that C=2(pi)r and V=(4/3)pi(r)
deltaf - f'(a)h, a= 40, V=(4/3)pi(C/2pi)^3
im not sure exactly how to compute to find the final answer but i believe that a = 40cm + or - 2cm and that somehow solving for r using circumference and then plugging it into the volume equation. if you can point me in the right direction i would appreciate it, thanks.
The easiest way is to assume maximum error (plus, then minus). Then take the difference between the calculated volume and true volume.
Or you could try expressing V as a function of C.
after solving for the volume when the radius is (21/pi) which is a +2cm error i got the answer 1251.1cm^3. when i solved for the volume when the radius was (19/pi) a -2cm error i got 926.6cm^3. last i solved for the actual measured raius which was 40 and found the radius to be (20/pi) when i solved for this i got 1080.8. i then subtracted 926.6 (-2cm error) from this answer and got 154.2. when i subtracted 1080.8 from 1251.1 (+2cm error minus actual) i got the answer 170.3. I'm guessing this means that the maximum error is 170.3cm^3. can anyone verify this?
V=(4/3)pi(C/2pi)^3= C^3/(6pi^2) is exactly what you want. What is the derivative of V with respect to C?
i think i finally got the answer to be 324.22pi by plugging in 40 to the above equation for C and then multipliing by delta x which in this case is 2
