Linear combinations euclidean algoritm extended
The discussion revolves around using the Euclidean Algorithm to find the greatest common divisor (gcd) of two numbers, specifically 83 and 36, and expressing it in the form d = ax + by. The user successfully applies the algorithm to find that gcd(83, 36) = 1, demonstrating the steps taken to reach this conclusion. They express the relationship in the required form, identifying coefficients a = -11 and b = 26. There is a query regarding the derivation of the coefficient 13 in the final expression, indicating a desire for clarity on the calculation process. The conversation highlights the methodical approach to solving linear combinations using the Euclidean Algorithm.
sg001
I have questions along the line of
Use the Euclidean Algorithm to find d= gcd(a,b) and x, y \in Z with d= ax +by
Ok so I use the euclidean algorithm as I know it on say gcd (83,36), by minusing of the the lowest number and repeating until i get the last non zero remainder ie, the gcd but I am completely lost on how to find the form ax +by, I know there must be some technique other than guessing and trial and error...
anyone care to let me in?
Yes, 36 divides into 83 twice with remainder 11: (I) 11= 83- 2(36).
Then 11 divides into 36 three times with remainder 3: (II) 3= 36- 3(11).
3 divides into 11 three times with remainder 2: (III) 2= 11- 3(3).
Finally, 2 divides into 3 once with remainder 1: (IV) 1= 3- 2 which tells us that the least common denominator is 1. (36 and 83 are "relatively prime".)
Now replace the "2" in equation (IV) with "11- 3(3)" from (III) to get
1= 3- (11- 3(3))= 3- 11+ 3(3)= 4(3)- 11.
Then replace the "(3)" in that equation by "36- 3(11)" from (II) to get
1= 4(36- 3(11))- 11= 4(36)- 12(11)- 11= 4(36)- 13(11).
Finally, replace the "(11)" in that equation by "83- 2(36)" from (I) to get
1= 4(36)- 11(83- 2(36))= 4(36)- 11(83)+ 22(36)= 26(36)- 11(83).
That is "d= ax+ by" with d=1, a= -11, b= 26.
Thanks that makes sense although I was hoping I could have acheived the result by ie gcd(83,36) =
83-36 =47 -36 = 36 -11 = 25 -11 = 14-11 = 11-3 = 8-3 = 5-3 = 3-2 = 2-1 = 1 !
and then I was hoping the coefficients would lie in there somewhere...
but I guess there's only some ways it will work
by the way how did you get the 13 in the fifth paragraph on the last expression?
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 20 ·
