linear programming, polyhedron and extreme points
  • Context: Graduate
  • Thread starter Thread starter mertcan
3 replies · 2K views
mertcan
Hi,
First assume that there is a polyhedron P, where Ax<=b and x is free variable whose dimension is n. Besides, rank(A) = n. I really wonder if extreme points in a polyhedron can be linearly dependent? I used even ChatGPT, but it includes some shaky calculations while proofing. In short, if extreme points in a polyhedron can be linearly dependent or not, could you provide me with a proof?
Thanks
mertcan said:
Hi,
Thanks
As an example you can consider a triangle in the plane R^2 with vertices
A=(0,1)
B=(1,0)
C=(1,1)
x<=1
y<=1
x+y>=1 ( -x-y<=-1 )
Reply
very thanks for your reply. Well, may I ask if ANY TWO extreme points in a polyhedron can be linearly dependent or not (those 2 extreme points are multiple of each other or not), could you provide me with a proof?
Thanks
It's trivial that you can get two points to be linearly dependent. For example the square with vertices (0,0), (0,1), (1,0) and (1,1). (0,0) Is linearly dependent with every other vertex.
Reply
