Linear Velocity vs Uniform Velocity
Uniformly increasing velocity refers to a linear increase in velocity, indicating constant acceleration in one-dimensional motion. The term "uniform" implies that the change occurs at a consistent rate over time. While "uniform exponential" suggests a different type of increase, "uniform" alone in this context typically denotes linearity. Therefore, stating "the velocity increases uniformly" does mean that the increments are linear, confirming constant acceleration. This clarification helps distinguish between different types of velocity changes in physics.
aunshih
I was hoping someone could help clarify. Does uniformly increasing velocity also mean linearly increasing velocity?
I found terms where it used uniform exponential. So I'm confused as to whether the word "uniform" used alone would also refer to a linear change.
What is the context?
Oh apologies. It for the basic one dimensional motion. Would it be correct for this statement "the velocity increases uniformly" to also mean that the increment is linear?
In other words, the acceleration is constant. Yes, I think it does mean that.
Many thanks.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
