Linearized Gravity: Why & How Does it Follow?
  • Thread starter Thread starter kexue
    Gravity
kexue
Why and how does from g_{ab}=\eta_{ab}+h_{ab} follow
g^{ab}=\eta^{ab}-h^{ab}?
Don't get the latex right, first equation all indices are supposed to below, second equation all are supposed to be up.
thanks
I think that you will arrive soon at this property.
If you work with GR, such a metric splitting does not mean introducing a flat space-time since the R is not zero whatever variable change you do.
thanks
Because then
<br /> g^{ab}g_{bc} = \delta^a_c<br />
up to first order. Maybe it helps to write
<br /> g_{ab} = \eta_{ab} + \epsilon h_{ab}<br />
then we would like that g_{ab}g^{bc}=\delta_a^c . So up to first order in epsilon you can easily see that g^{bc}=\eta^{bc} - \epsilon h^{bc}
does the job for you:
<br /> g_{ab}g^{bc} = ( \eta_{ab} + \epsilon h_{ab}) (\eta^{bc} - \epsilon h^{bc})<br /> = \delta_a^c + \epsilon(h_{ab}\eta^{bc} - h^{bc}\eta_{ab}) + O(\epsilon^2)<br />
Now, you can raise the indices of h with eta because we are working at linear order in epsilon; every correction to it would give higher order epsilon terms. So we get
<br /> g_{ab}g^{bc} = \delta_a^c + \epsilon (h_a^c - h_a^c) + O(\epsilon^2) = \delta_a^c + O(\epsilon^2) <br />
You could say that the minus-sign in g^{ab} is for cancelling the two factors linear in epsilon in order to get g_{ab}g^{bc}=\delta_a^c. Ofcourse, if you go up higher in order epsilon, say epsilon squared, then all the terms quadratic in epsilon have to cancel to maintain the identity g_{ab}g^{bc}=\delta_a^c.
thanks so much, haushofer! crystal-clear now
I asked a question here, probably over 15 years ago on entanglement and I appreciated the thoughtful answers I received back then. The intervening years haven't made me any more knowledgeable in physics, so forgive my naïveté ! If a have a piece of paper in an area of high gravity, lets say near a black hole, and I draw a triangle on this paper and 'measure' the angles of the triangle, will they add to 180 degrees? How about if I'm looking at this paper outside of the (reasonable)...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
