Linearizing an explicit differentiation scheme
Pietair
Consider the following implicit scheme:
y_{n+1}=y_{n}+\frac{\Delta t}{2}\left [f(y_{n+1})+f(y_{n})]
By linearization one can obtain an explicit scheme which is an approximation to this - with approximation error O(\Delta t^{3})
The solution is:
y_{n+1}=y_{n}+\Delta t\left [1-\frac{1}{2}\Delta t f'(y_{n}) \right ]^{-1}f(y_{n})
And the notation: y'(x)=f(x,y(x))
I think I have to take the Taylor expansion of f(y_{n+1})
I get:
f(y_{n+1})=f(y_{n})+\Delta tf'(y_{n})+O(\Delta t^{2})
Substituting in the main scheme:
y_{n+1}=y_{n}+\frac{\Delta t}{2}\left [f(y_{n})+\Delta tf'(y_{n})+O(\Delta t^{2})+f(y_{n})]f(y_{n+1})=y_{n}+\frac{\Delta t}{2}\left [f(y_{n})+\Delta ty'(y_{n})+O(\Delta t^{2})+f(y_{n})]f(y_{n+1})
This expression is, as far as I can see, not equal to the expression of the solution.
Any help would be appreciated!
y_{n+1}=y_{n}+\frac{\Delta t}{2}\left [f(y_{n+1})+f(y_{n})\right]
The solution is:
I get:
y_{n+1}=y_{n}+\frac{\Delta t}{2}\left [f(y_{n})+\Delta tf'(y_{n})+O(\Delta t^{2})+f(y_{n})\right]f(y_{n+1})=y_{n}+\frac{\Delta t}{2}\left [f(y_{n})+\Delta ty'(y_{n})+O(\Delta t^{2})+f(y_{n})\right]f(y_{n+1})
You are missing the "\right" code with several of your "]" symbols. (Corrected in Quote.)
This is what I did, it may help you it may not.
<br /> \begin{array}{rcl}<br /> f(y_{n+1}) &amp; = &amp; f\left( y_{n}+\frac{\delta t}{2}X\right) \\<br /> &amp; = &amp; f(y_{n}+\frac{X\delta t}{2}f&#039;(y_{n}) \\<br /> &amp; = &amp; f(y_{n})+ \frac{\delta t}{2}(f(y_{n+1})+f(y_{n}))f&#039;(y_{n})<br /> \end{array}<br />
where X=f(y_{n+1})+f(y_{n}) and we can solve for f(y_{n+1}), to obtain:
<br /> f(y_{n+1})=\left( 1-\frac{\delta t}{2}f&#039;(y_{n})\right)^{-1}\left( 2f(y_{n})+\frac{\delta t}{2}f&#039;(y_{n})\right)<br />
Substitute this into your equation.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
