Liouville's theorem - (probably) easy question
  • Thread starter jinsing
    Theorem
4 replies · 2K views · last reply
jinsing
If f is an entire function and |f(z)|\leq C|z|^(1/2) for all complex numbers z, where C is a positive constant, show that f is constant.
All bounded and entire functions are constant.
I'm 99% sure this can be easily proven using Liouville's theorem, I'm just having trouble proving that f is bounded above by a constant. What should I do with the |z|^(1/2) term?
Thanks for the help!
You can't prove it directly with Liouville's theorem, since f(z) isn't bounded. You could look at how Liouville's theorem is proved and adapt the proof.
Would that involve looking at the Cauchy differentiation formula and using the maximum*length principle? Is it because f is entire we know we can use CDF? In other words, do we know there exists a z_0 inside a simple closed curve gamma such that CDF holds because f is entire?
Yes, it would. If |f(z)| is bounded you can use the Cauchy integral formula to show all of the ak for k>0 in the power series expansion are equal to zero. |f(z)|<C|z^(1/2)| is also good enough. Basically the same proof.
