Locating Position of Point P(x,y): Lines, Quadrilaterals & Triangles
  • Thread starter Thread starter atavistic
    Point Position
The discussion focuses on determining the position of a point P(x,y) relative to various geometric constructs, including two lines, a single line, quadrilaterals, and triangles. Key inquiries include whether the point lies between or outside two lines, its position in relation to the upper or lower regions of a line, and its location inside a quadrilateral or triangle. Participants emphasize the need for clarification on the definitions of "locate," "upper," "lower," "left," and "right" in the context of oblique lines. The importance of showing prior attempts or understanding the theoretical basis behind these geometric concepts is highlighted. Overall, the conversation seeks to establish a clearer framework for analyzing the position of point P in relation to these shapes.
atavistic
How to locate position of a point say P(x,y) according to the following:
a) 2 lines (ax+by+c=0) and (AX+BY+C=0)(in between or outside)
b)IN the upper region or in the lower region of a line(ax+by+c=0)
c)IN the left or right region of a line(almost same as above)
d)INside a Quadilateral or not
e)INside a triangle or not.
Are you given anything to look at or is this all that is given?
First, I really don't understand what you're asking us... I don't see a question mark.
But, more importantly, you need to show us what you've attempted before we can begin to help you.
Are these 4 separate conditions- 4 separate questions? What do you mean by "locate". What would you accept as the "location" of a point? What do you mean by "upper" and "lower" or "left" and "right" region of an oblique line?
I am just asking the theory and not an answer.I mean what results will I obtain when I put the point (x,y) in the equation of line(s).And with the result what can I know about the position of the point.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
