Location of an object moving in a circular path
  • Thread starter Thread starter vbman11
    Circular Path
To find the location of an object moving in a circular path using speed and radius, the parametric equations x = r cos(α) and y = r sin(α) can be utilized. The angle α, measured in radians, can be determined by calculating the period of revolution based on the object's speed. By dividing the distance traveled by the circumference of the circle and multiplying by 2π, the correct radians can be derived for α. This approach allows for the computation of the object's position (x, y) over time. Understanding these relationships is essential for accurately modeling circular motion in Cartesian coordinates.
vbman11
if i know the speed and the radius of the turn how can I find the location of the object(x,y Cartesian) of the object with Time?
You could describe the circle parametrically as:
x=r cos (\alpha)
y=r sin (\alpha)
Then, knowing v, you can find the period it should take for the object to complete one revolution and compute alpha in terms of your normal time variable.
ok so, I am guessing \alpha is the angle in radians and r is the radius. so I use the speed(s) and time(t) to get the distance then divide that by the circumference then multiply by 2\pi to get the radians to put into those equations?
comparing a flat solar panel of area 2π r² and a hemisphere of the same area, the hemispherical solar panel would only occupy the area π r² of while the flat panel would occupy an entire 2π r² of land. wouldn't the hemispherical version have the same area of panel exposed to the sun, occupy less land space and can therefore increase the number of panels one land can have fitted? this would increase the power output proportionally as well. when I searched it up I wasn't satisfied with...
