Locus of Mid Point: X-Axis Cut Points
  • Thread starter Thread starter phymatter
    Point
The locus of midpoints from the point (6,-8) to the x-axis is determined to be the line y = -4. The midpoint formula yields coordinates of the form ((6+x)/2, -4), where x represents various x-axis cut points. The x-coordinate can take any real value, but the y-coordinate remains constant at -4, forming a horizontal line. This conclusion is supported by the properties of similar triangles, where the midpoints of two sides are parallel to the third side. Thus, the locus of all midpoints is confirmed as y = -4.
phymatter
From the point (6,-8) all possible lines are drawn to cut x-axis , find the locus of their middle ponts
none
i got the coordinates of the middle point as ((6+x)/2 ,-4 ) , but what will the locus be ?
The expression you have gives you the locus. What do all of the midpoints have in common?
you mean that the locus is y=-4 neglecting the term containing x , but why are we neglecting x ? i mean if we put different values of x we get different mid points , so why are we neglecting it??
pls. help , its getting over my head :((
Draw a right angled triangle and join the midpoints of two sides. This new line will be parallel to the third side. Similarly, in any triangle, the line between the midpoints of two sides is parallel to the third side. You can prove this because the smaller triangle is similar to the larger, so the corresponding angles are equal.
If the apex is (6,-8) and the third side is the x-axis, the line between the midpoints is the locus. Does this convince you?
You're neglecting the x, because the image of \frac{6 + x}{2} spreads over the real number. What I mean is:
\forall x_0 \in \mathbb{R} , \exists x \in \mathbb{R} : \frac{6 + x}{2} = x_0.
So, take any real number x0, the point (x0; -4) is the midpoint of the line segment, of which 2 ends are (6; -8), and \left( 2x_0 - 6; 0 \right).
Hope I'm being clear enough. :)
All points of the form ((6+x)/2 ,-4 ) satisfy y= -4 and that is the equation of the locus, a horizontal line. The "(6+x)/2" gives the x coordinate of a point on that line (for x being the x coordinate of the point (x, 0) that the line from (6, -8) is drawn through).
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
