Why Are My 4-Point Probe Measurements Failing?
The discussion centers on challenges faced while measuring electrical conductivity of conductive polymer films using the 4-point probe technique. Users report issues such as films burning out due to the Joule effect, lack of voltage drop detection in semiconducting samples, and fluctuating voltage measurements from the digital multimeter. Suggestions include using a shunt resistor to limit current, employing a lock-in amplifier for better signal-to-noise ratio, and ensuring proper lead attachment to the samples. The conversation emphasizes the importance of addressing these technical difficulties to successfully obtain conductivity measurements. Overall, effective troubleshooting methods are crucial for accurate 4-point probe measurements.
rury_cruz
4 point probe measurement help!
I will really appreciate if somebody can help me:
I was trying to measure the electrical conductivity of some conductive polymer films using the 4 point probe technique. Altough is widely described and seems easy to arrange, I have been unable to measure my samples due to the following problems:
1.- As soon as I turn on the power source the films burns out (like a fuse)due to the joule effect, I guess, even when I set the power source in the "constant current" mode, fixed to the minimum.
2.- When I tried to measure the electrical conductivity of the semiconducting samples, (or at least I thought so...), no voltage drop is detected between the inner probes, and no current flows at all. It seems to be "too insulating" to close the circuit
3.- The digital multimetter is always changing the voltage drop measurement, whether the current source is on or off. Could it be due to the connections?... some bi-metalic joint effect?
I hope some of you have done this kind of measurements before, I really need to know the conductivity of my samples. If you need further information feel free to contact me...
Likes Hanyuri
For the first problem you could put a shunt resistor in the cicuit to limit the current through the sample.
If the sample is insulating then you won't read a votlage across the inner leads.
A perferred method is to use a lockin-amp and measure the AC-resistance. It will give you a better S/N ratio. Otherwise you might need a nanovolt meter you get decent results.
How are you attaching your leads to the sample? This was a major problem that I ran into while making these type measurements.
JMD
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
